HiVi D6G 6" Kevlar/Paper Woofer
Brand:|Model: D6G|Part # 297-420
The HiVi D6G speaker represents a design in which the voice coil is positioned over a large thermally stabilized neodymium magnet and undercut pole piece.
List Price$227.99
You Save55%
$103.00
Buy 4-11 $89.42
Buy 12+$75.31
Part # 297-420
  • Light and extremely rigid cone made from Kevlar/paper composite
  • High loss rubber surround
  • Shielded vented Neodymium magnet system
  • Long-throw motor structure
  • High linear excursion capability
  • High-density aluminum die-cast frame
The HiVi D6G speaker represents a design in which the voice coil is positioned over a large thermally stabilized neodymium magnet and undercut pole piece. A specially shaped, CNC machined steel cup completes the magnetic structure from the outside, creating a shielded magnet system with symmetrical flux density distribution along the gap. The long-throw voice coil experiences a symmetric driving force that substantially decreases inductance and back electromotive force modulations. The whole magnet structure is optimized using the Finite Element Analysis technique, and the result is a radical improvement of driver linearity. The cone is fabricated from a newly developed matrix of Kevlar and paper fibers. It has a shallow, high integrity structure, which is extremely rigid and dynamically stable. A large voice coil diameter allows for much more uniform cone movement, resulting in clear and accurate reproduction. The vented motor design effectively transfers heat to the die-cast frame, and along with a high temperature Kapton former voice coil, provides a dramatic increase in power handling.
  • Nominal Diameter6"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response50 to 2,000 Hz
  • Sensitivity85 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)44 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)4.08
  • Electromagnetic Q (Qes)0.43
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.43 ft.³
  • Mechanical Compliance of Suspension (Cms)0.58 mm/N
  • BL Product (BL)9.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)21.6g
  • Maximum Linear Excursion (Xmax)5.3 mm
  • Surface Area of Cone (Sd)121 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Voice Coil Wire MaterialCCA
  • Magnet MaterialNeodymium
  • Overall Outside Diameter6.83"
  • Baffle Cutout Diameter5.32"
  • Depth3.01"
  • # Mounting Holes12
  • Sealed Volume0.23 ft.³
  • Sealed F379 Hz
  • Vented Volume0.71 ft.³
  • Vented F339 Hz
  • BrandHiVi
  • ModelD6G
  • Part Number297-420
  • UPC844632021268
  • Product CategoryWoofers
    (6 Reviews)
  • Weight3.53 lbs.
View similar products to the HiVi D6G 6" Kevlar/Paper Woofer
