HiVi D5.8 5" Poly Bass/Midrange Shielded
Brand:|Model: D5.8|Part # 297-439
The HiVi D5.8 speaker's design positions the voice coil over an undercut central pole piece with a large thermally stabilized neodymium magnet at the bottom.
Part # 297-439
  • Shallow mineral filled polypropylene cone
  • Specially made high loss rubber surround
  • Shielded vented magnet system with neodymium magnet
  • Long-throw symmetrically driven motor structure
  • High power handling voice coil with a 76 mm Kapton former
  • High density aluminum die-cast frame
The HiVi D5.8 speaker's design positions the voice coil over an undercut central pole piece with a large thermally stabilized neodymium magnet at the bottom. A specially shaped, CNC-machined steel cup completes the magnetic structure from the outside, creating a shielded magnet system with symmetrical flux density distribution along the gap. The long-throw voice coil experiences a symmetric driving force that substantially decreases inductance and back electromotive force modulations. The magnet structure is optimized using Finite Element Analysis technique, resulting in a radical improvement of driver linearity. The cone's shallow, high integrity structure is extremely rigid and dynamically stable. The large voice coil diameter facillitates uniform cone movement, resulting in clear and accurate reproduction. The vented design and high temperature rated voice coil provide a dramatic increase in power handling. Suitable for compact vented box systems, the D5.8 is capable of delivering incredibly deep and dynamic bass for its size.
  • Nominal Diameter5"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response60 to 2,500 Hz
  • Sensitivity83 dB 2.83V/1m
  • Voice Coil Diameter3"
  • Resonant Frequency (Fs)52 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)3.07
  • Electromagnetic Q (Qes)0.42
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.2 ft.³
  • Mechanical Compliance of Suspension (Cms)0.52 mm/N
  • BL Product (BL)9 Tm
  • Diaphragm Mass Inc. Airload (Mms)17.3g
  • Maximum Linear Excursion (Xmax)4.8 mm
  • Surface Area of Cone (Sd)87 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter5.31"
  • Baffle Cutout Diameter4.98"
  • Depth2.59"
  • # Mounting Holes6
  • Sealed Volume0.07 ft.³
  • Sealed F3101 Hz
  • Vented Volume0.19 ft.³
  • Vented F356 Hz
  • BrandHiVi
  • ModelD5.8
  • Part Number297-439
  • UPC844632021848
  • Product CategoryWoofers
    (2 Reviews)
  • Weight3.5 lbs.
View similar products to the HiVi D5.8 5" Poly Bass/Midrange Shielded
