HiVi D10.8 10" Poly Cone Woofer
Brand:|Model: D10.8|Part # 297-453
The HiVi D10.8 represents a design in which the voice coil is positioned over an undercut central pole piece with a large thermally stabilized neodymium magnet at the bottom and a high energy ceramic magnet on the top.
List Price$330.99
You Save44%
$185.50
Buy 4-23 $175.52
Buy 24+$165.85
Part # 297-453
  • Shallow mineral filled polypropylene cone
  • Shielded vented magnet system with a huge Neodymium magnet
  • Fatigue resistant foam surround
  • Long-throw symmetrically driving motor structure
  • Extreme power handling voice coil with a 100 mm black anodized aluminum former
  • High density aluminum die-cast frame
  • Progressive spider with decompressed rear volume
The HiVi D10.8 represents a design in which the voice coil is positioned over an undercut central pole piece with a large thermally stabilized neodymium magnet at the bottom and a high energy ceramic magnet on the top. A specially shaped, CNC machined steel cup completes the magnetic structure from the outside, creating a shielded magnet system with symmetrical flux density distribution along the gap. The long-throw voice coil experiences a symmetric driving force that substantially decreases inductance and back electromotive force modulations. The magnet structure is optimized using Finite Element Analysis technique, resulting in a radical improvement of driver linearity. The cone has a shallow, high integrity structure that is extremely rigid and dynamically stable. The large voice coil diameter allows for a more uniform cone movement, delivering clear and accurate reproduction. The vented motor design and high temperature rated voice coil provide a dramatic increase in power handling. D10.8 is an excellent woofer for high power "no compromise" audiophile systems and control monitors. It also may be used as a subwoofer in various configurations.
  • Nominal Diameter10"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response24 to 2,300 Hz
  • Sensitivity90 dB 2.83V/1m
  • Voice Coil Diameter4"
  • Resonant Frequency (Fs)24 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)6.84
  • Electromagnetic Q (Qes)0.44
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)5.2 ft.³
  • Mechanical Compliance of Suspension (Cms)0.56 mm/N
  • BL Product (BL)13.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)75.5g
  • Maximum Linear Excursion (Xmax)8 mm
  • Surface Area of Cone (Sd)434 cm²
  • Cone MaterialPoly
  • Surround MaterialFoam
  • Voice Coil Wire MaterialCCA
  • Magnet MaterialNeodymium
  • Overall Outside Diameter10.87"
  • Baffle Cutout Diameter10.04"
  • Depth4.21"
  • # Mounting Holes12
  • Sealed Volume1.93 ft.³
  • Sealed F343 Hz
  • Vented Volume5.71 ft.³
  • Vented F324 Hz
  • BrandHiVi
  • ModelD10.8
  • Part Number297-453
  • UPC844632021879
  • Product CategoryWoofers
    (4 Reviews)
  • Weight11.26 lbs.
View similar products to the HiVi D10.8 10" Poly Cone Woofer
HiVi D10.8 10" Poly Cone Woofer is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from PhenomenalModels beautifully in a t-line, and performance matches the modeling. 100 inch line, with a 7:1 taper ratio in a 3 way cab, means your left and right channels will have full subwoofer performance, but the musicality and fidelity of a completely high end system. Now with another separate sub, your system acts as if it has 3 subs, which is PHENOMENAL!!! You now have the equivalent of the live performance venue or recording studio, in your own living room. I have a professional degree, I am an advanced hobbyist, and an amateur musician.
Date published: 2012-04-03
Rated 5 out of 5 by from Take these drivers very seriously.I'm running 4 of these with the new Vifa/Peerless NE series 7" midwoofers and a pair of ScanSpeak Illuminator Tweeters. The bass is truly exceptional, tight, controlled, accurate and very punchy. I'm running them with an NHT X2 crossover to do a little bass EQ and a Soundstream DA-1 power amplifier. Some of the most musical bass I've ever heard. Just blows away my Aerial 10T's.
Date published: 2012-03-03
Rated 4 out of 5 by from VERY nice for the moneyLow end won't get past these guys. They are tight and crisp,ZZ Top sounds insane. Matched them with Vifa midrange and tweeter and bi-amped them, top dollar 3 way speakers without breaking the bank.
Date published: 2008-12-03
Rated 4 out of 5 by from Decent wooferUsed In Open Baffle & ported box as sub. Decent quality unit, good sound, deep bass.
Date published: 2007-10-06
  • 2016-02-13T06:38CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_297-453, PRD, sort_mostRecent
(...foam surround on a woofer?)  any rubber surround kits available for this otherwise interesting driver?
Asked by: tajanes
I am sorry, there are not any rubber surrounds for this. Changing the surround material would have a major impact on the drivers specifications. They are different weights and very different pliability.
Answered by: Chrisf
Date published: 2016-02-01
I am seeking to use this in a mobile audio install on the rear deck. I am seeking frequency response between 40-90hz in a sealed enclosure. I would be using two of them. What would be the smallest recommended enclosure size? Will 1 cu.ft. work?
Asked by: sambris
These will work well in small sealed volumes. The ideal volume would be 1 cubic foot per woofer, but if you are asking about using both in that volume it will still work, you just need to have about a pound of stuffing for each. This will result in an F10 in the low 30's which can be the expected usable response in a vehicle.
Date published: 2016-01-26
Is this a good replacement driver to a Mordaunt-Short Aviano 7 subwoofer?
Asked by: razec
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-07-06
How will HiVi D10.8 10" Poly Cone Woofer work in a two way system, 1.6 cu.ft. sealed enclosure crossed at 1.5K ,18 Db per Octive slope..?
Asked by: 604E
Even though the published frequency response claims extension to 2,300 Hz, the frequency response graph shows a peak at about 600 and then it drops above that. This woofer will work best in a three way with a dedicated mid crossed around 300-500 Hz.
Date published: 2015-04-14
Would these be an exact replacement for the DYNAUDIO 30D100XL drivers? We need to replace four old woofers in two Dynaudio M3a three-way active studio monitors?
Asked by: BEGE
Unfortunately we do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-09-09
How would this do in a 1.4 to 1.5 foot sealed cabinet as far as freq response and sensitivity?
Asked by: ocezam
This will work well in that volume, reaching low 30's in room. Sensitivity will not change from what is published.
Date published: 2014-08-18
  • 2016-02-13T07:31CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_297-453, PRD, sort_recentQuestionsFirst
