HiVi B4N 4" Aluminum Midbass Round Frame
Brand:|Model: B4N|Part # 297-429
Bronze/aluminum alloy cones, rubber surrounds, cosmetic steel frames, and shielded motor structures are the distinguishing features of HiVi's B Series full-range speakers.
List Price$26.99
You Save45%
$14.91
Buy 4-8 $12.40
Buy 9+$11.24
Part # 297-429
  • Capable of covering a wide portion of the audio spectrum
  • Magnetically shielded design allows use in center channel and other multimedia applications
Bronze/aluminum alloy cones, rubber surrounds, cosmetic steel frames, and shielded motor structures are the distinguishing features of HiVi's B Series full-range speakers. The B4N drivers are capable of covering a wide portion of the audio spectrum, and the magnetically shielded design allows use in center channel and other multimedia applications.
  • Nominal Diameter4"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response60 to 4,000 Hz
  • Sensitivity85 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)56 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)3.91
  • Electromagnetic Q (Qes)0.63
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)0.16 ft.³
  • Mechanical Compliance of Suspension (Cms)1.11 mm/N
  • BL Product (BL)5.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)6.8g
  • Maximum Linear Excursion (Xmax)3.2 mm
  • Surface Area of Cone (Sd)53 cm²
  • Cone MaterialAluminum / Magnesium
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.59"
  • Baffle Cutout Diameter3.66"
  • Depth2.85"
  • # Mounting Holes4
  • Sealed Volume0.08 ft.³
  • Sealed F392 Hz
  • Vented Volume0.27 ft.³
  • Vented F346 Hz
  • BrandHiVi
  • ModelB4N
  • Part Number297-429
  • UPC844632024979
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (35 Reviews)
  • Weight2 lbs.
View similar products to the HiVi B4N 4" Aluminum Midbass Round Frame
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
