HiVi B3N 3" Aluminum Driver Round Frame
Brand:|Model: B3N|Part # 297-428
Bronze/aluminum alloy cones, rubber surrounds, cosmetic steel frames, and shielded motor structures are the distinguishing features of the HiVi B Series full-range speakers.
List Price$16.99
You Save41%
$9.98
Buy 4-11 $8.44
Buy 12+$7.51
Part # 297-428
Bronze/aluminum alloy cones, rubber surrounds, cosmetic steel frames, and shielded motor structures are the distinguishing features of the HiVi B Series full-range speakers. These drivers are capable of covering a wide portion of the audio spectrum, and the magnetically shielded design allows use in center channel and other multimedia applications.
  • Nominal Diameter3"
  • Power Handling (RMS)10 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response80 to 12,000 Hz
  • Sensitivity81 dB 2.83V/1m
  • Voice Coil Diameter0.75"
  • Resonant Frequency (Fs)77 Hz
  • DC Resistance (Re)6.5 ohms
  • Mechanical Q (Qms)4.48
  • Electromagnetic Q (Qes)1.07
  • Total Q (Qts)0.86
  • Compliance Equivalent Volume (Vas)0.06 ft.³
  • Mechanical Compliance of Suspension (Cms)1.32 mm/N
  • BL Product (BL)3.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)3.2g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)30 cm²
  • Cone MaterialAluminum
  • Voice Coil Wire MaterialCCA
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.5"
  • Baffle Cutout Diameter2.875"
  • Depth2.125"
  • # Mounting Holes4
  • Sealed Volume0.16 ft.³
  • Sealed F376 Hz
  • Vented Volume0.28 ft.³
  • Vented F344 Hz
  • BrandHiVi
  • ModelB3N
  • Part Number297-428
  • UPC844632024962
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (40 Reviews)
  • Weight1.2 lbs.
View similar products to the HiVi B3N 3" Aluminum Driver Round Frame
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
