High Power White LED 10W with Heatsink
Brand:| Model: DC-LE14114
When a lot of light is needed, count on high power white LEDs.
  • Great for DIY security lights
  • Combine with fiber optics for amazing lighting effects
  • Low power requirement
  • Ultra-wide 140° viewing angle with 450 lumens of output
073-036
Weight: 0.2 lbs.
IN STOCK
List Price$14.99
You Save33%
$9.97
Buy 4-up$9.47
Part # 073-036
Create high power lights with the High Power series of LEDs; with 450 lumens of output and a 140° viewing angle you are sure to find your way. A low power requirement allows you to build an array that sips current, for hours of use. Heatsink included and required for operation. RoHS compliant.
Specifications: • Heatsink size: 2.95" L x 2.95" W x 0.51" H (75 x 75 x 13 mm) • Lens color: Water clear • Forward current: 1.6A • Forward voltage: 8.0 VDC • Viewing angle: 140° • Luminous intensity: 450 lumens (108,000 mcd @ 140°) • Lifetime: 100,000 hours.
Note: The positive terminal has a half-circle notch at the tip of the terminal. Do not stare directly into LED when in use. Do not apply power to this LED without a proper heatsink in place.
  • BrandParts Express
  • ModelDC-LE14114
  • Part Number073-036
  • UPC844632093524
  • Product CategoryHigh-Power LED Assemblies
    (2 Reviews)
  • Weight0.2 lbs.
View similar products to the High Power White LED 10W with Heatsink
in the High-Power LED Assemblies product category.
High Power White LED 10W with Heatsink is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from A lot of light in a user-configurable packageI needed this exact configuration - lots of "bright white" output, smallish footprint and an external circuitry requirement. The premise is simple. The light could not interfere with a sensitive RF receiver system inches away on a test bench. Using two of them wired in series, I achieved desired results with a self-designed, constant current regulator set to deliver 19.1V at 1.04A to two series-wired LEDs. I purchased a Hammond DieCast enclosure and put the toroid transformer, rectifier and regulation components, then attached the LED's heatsinks to the lid. Two studs protrude through the bottom and mount to a bracket on my desk.Granted, it's not the most efficient method of powering these LEDs, but it is the most electrically quiet for my purposes.
Date published: 2015-02-15
Rated 4 out of 5 by from Wow, unbelievable brightnessWow, unbelievable brightness. It lights up the backyard.They weren’t kidding when they say; don’t look directly into the LED when powered on.I know, what I’m I stupid or what, lol.The heatsink gets pretty hot. I reapplied new and more thermo compound under the LED.I would suggest a fan to cool, so I placed a very small 1½ inch 12volt/0.6w fan under. I measured the voltage across the LED with the fan connected, 10vdc. Not sure if the fan connected to the LED and driver module 073-054 will hinder the performance output. I don’t think so because the little amount of power the fan draws shouldn’t harm it. If my Fluke 51 is working properly, I placed the temp sensor on top of the LED to measure the temperature. The temperature was 320 degrees Fahrenheit/163 Celsius.Don’t touch the powered LED. And yes it draws 1.5 Amps at 12vdc. not sure what I'm going to do with right now. Would be great for camping.
Date published: 2012-09-14
  • 2015-05-27T08:36CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.3
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_073-036, PRD, sort_mostRecent
Can two of these be powered by one High Power LED Driver 10/20W Part # 073-054?
Asked by: DJ Dave
Yes, that driver will power up to four (4) LEDs in series, as stated in the product description.
Answered by: RussR
Date published: 2012-01-20
  • 2015-05-27T09:05CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.3
  • loc_en_US, sid_073-036, PRD, sort_recentQuestionsFirst
Customer projects that include: High Power White LED 10W with Heatsink
