Clearance Item
073-078_ALT_0
073-078_ALT_1
073-078_ALT_2
073-078_ALT_3
073-078_ALT_4
High Power RGB LED Kit w/Power Supply and Audio Sync
Brand:| Model: LE-LL21118
Product Video
Create amazing audio synced effects with this RGB LED kit.
  • Perfect when paired with fiber optics to create an audio synced light show
  • Amazing output combined with long life
  • Ultra-wide 160° viewing angle
  • Includes audio sync color organ board, one quadcolor RGBY LED board, and three high power 3W (1W per color) RGB LEDs
073-078
Weight: 0.85 lbs.
IN STOCK
List Price$69.99
Regular Price$49.90
You Save40%
Sale Price
$30.00
Part # 073-078
Creating an audio synchronized light show is made easy with this RGB LED driver with audio sync. As a four channel color organ, the audio input signal is filtered into one of four categories by frequency: low, medium, medium-high, and high. Each frequency category is then assigned a specific pulse width modulated output that feeds to the 4 x 1W quadcolor LED board for power and control. See below for frequency divisions and default color assignment.
This kit includes one quadcolor LED board that can be mounted nearly anywhere. 8-pin input and output connectors (mounted on the bottom of the board) offer quick connection to the audio sync controller and for connecting up to six additional quadcolor RGBY LED boards. Four dip switches on the circuit board offer color control of either the on-board LEDs or both on-board and external RGB LEDs. (see manual in the Manuals/Resources section on the right for more information).
Three individual RGB LEDs are included for versatility and to extend use to other applications such as: flashlights, reading lights, decoration, automotive lighting, and outdoor lighting. 3W RGB LEDs (1W per color) feature some of the highest flux densities available and live up to 100,000 hours (over 10 years). Low power requirements allow for hours of use off battery power. Connect to RGBY quadcolor board (see manual for instructions).
Kit Contains:
• One audio sync RGB LED driver board
• One RGBY quadcolor LED board
• Three 3W (1W/color) RGB LEDs
• One AC-DC power adapter (requires figure-eight power cord and 2.1 mm x 5.5 mm plug tip, please see related items)
• Six 4" 22 AWG wires
• Four M3 x 6 mm bolts
• Eight M3 x 6 mm socket head screws
• Two 8-pin F-F cables
Audio Sync Board Specifications: • Power requirement: 12 VDC, 1A (2A recommended) • DC power jack: 2.1 mm ID, 5.5 mm OD • Audio input/output: 3.5 mm • Dimensions: 3" W x 3" L x 0.74" H (76.2 x 76.2 x 18.7 mm).
Audio Sync Frequency Divisions:
• Low: 0-600 Hz • Medium: 600-3,000 Hz • Medium-high: 3,000-6,000 Hz • High: 6,000-20,000 Hz
Audio Sync Default Color Assignments:
• Low: White or yellow • Medium: Blue • Medium-high: Green • High: Red
Quadcolor RGBY Board Specifications: • Power requirement: 9 to 25 VDC (19 VDC, 2.1A power supply recommended) • Power input jack: 2.1 mm ID x 5.5 mm OD • Dimensions: 3" W x 3" L (76.2 x 76.2 mm).
Quadcolor RGBY LED Specifications (nominal): Red: 625 nm wavelength, 45 lumens • Green: 530 nm wavelength, 75 lumens • Blue: 470 nm wavelength, 23 lumens • Yellow: 590 nm wavelength, 43 lumens.
3W (1W/color) RGB LED Specifications: • Size: 0.79" dia. x 0.16" H (20 x 4 mm) • Lens color: Water clear • Forward current: 350 mA (per color) • Forward voltage: 2.2 to 2.8 VDC (red), 3.0 to 3.8 VDC (green), 3.0 to 3.8 VDC (blue) • Viewing angle: 160° • Luminous intensity: 30 lumens (red), 55 lumens (green), 9 lumens (blue) • Lifetime: 100,000 hours.
Note: Do not stare directly at LEDs when in use. Please connect power adapter to quadcolor RGBY LED board for system power after all the connections are made.
  • BrandParts Express
  • ModelLE-LL21118
  • Part Number073-078
  • UPC844632093739
  • Product CategoryHigh-Power LED Assemblies
  • Weight0.85 lbs.
View similar products to the High Power RGB LED Kit w/Power Supply and Audio Sync
in the High-Power LED Assemblies product category.
Do the separate 3W RGBs require a heat sink?
Asked by: frizzo1
No these LEDs do not require a heat sink.
Date published: 2012-11-13
  • 2015-03-05T09:46CST
  • loc_en_US, sid_073-078, PRD, sort_recentQuestionsFirst
Videos
Customer projects that include: High Power RGB LED Kit w/Power Supply and Audio Sync
