Heavy Duty Soldering Iron Stand
Brand:|Part # 370-350
Heavy duty stand features a weighted iron base, large sponge tray, and metal iron holder. Built to withstand everyday industrial use.
List Price$9.99
You Save30%
$6.95
Buy 4-19 $6.50
Buy 20+$5.96
Part # 370-350
  • Weighted iron base to hold multiple types of soldering irons
  • Large sponge tray keeps your iron clean
Heavy duty stand features a weighted iron base, large sponge tray, and metal iron holder. Built to withstand everyday industrial use. Dimensions: 4-1/4" x 3" x 5".
  • BrandParts Express
  • Part Number370-350
  • UPC844632013577
  • Product CategorySoldering Stands & Accessories
    (21 Reviews)
  • Weight0.758 lbs.
View similar products to the Heavy Duty Soldering Iron Stand
in the Soldering Stands & Accessories product category.
Heavy Duty Soldering Iron Stand is rated 4.3333 out of 5 by 21.
Rated 2 out of 5 by from Great, but...The intent of the manufacturer was, without doubt, to produce a great soldering iron stand. The base is is cast iron giving stability both for the tool and the stand itself on the bench.The coil holding the iron is spot-welded to the inclined wire which screws into the base. Those welds break-up when one attempts to install the top plastic collar into the coil. I fixed it with twisted wire, but I did not expect to have to, right out of the box and for such a simple object.
Date published: 2015-11-13
Rated 5 out of 5 by from SturdyItem is sturdy and just what hubby wanted. Super fast shipping and a great price
Date published: 2014-12-30
Rated 4 out of 5 by from It worksIt's a reasonable stand. Base is solid metal so there's some heft to it. Interestingly, the coil that holds the soldering iron does not have any flex; the mount that attaches it to the base is secured to every turn of the coil.Here's a rhetorical question: why do all the stands hold the iron with the tip down? Heat rises, right? So why not find a way to store the iron so that the tip gets hotter and the handle cooler, rather than the other way around? I have yet to see an iron stand/holder that holds it level or even tip-up.
Date published: 2014-11-06
Rated 5 out of 5 by from Better than expectedThis is a solid, heavy stand that compliments all soldering irons.
Date published: 2014-02-01
Rated 3 out of 5 by from Works fine, but made to a price pointThis stand has a decently heavy cast metal (iron?) base, and it fits my Weller soldering iron pretty well.    My only small gripe, is that the black plastic ring does not fit 100% into the "spring" section.   On my unit, the plastic ring only passes through the outer 2 coils of the spring, but absolutely will not go into any more, since the spring at that depth is welded and will not expand enough.   Also, the "spring" is really soft metal and bends easily, so if you reef on the plastic ring trying to fully insert it, you'll. bend the coil and have to straighten it.   The sponge is the thin disk in the box - it seems more like a normal dish sponge than the square sponge that PEX sells for other stands, but it does seem to work fine as long as you keep it wet.
Date published: 2014-01-21
Rated 4 out of 5 by from FOR ELECTRONIC PROJECTSWHEN I ORDERED, THIS PRODUCT, I THOUGHT IT WOULDHAVE A SLIGHTLY BIGGER ROUND BASE, BUT IT IS STILL USEABLE AND WORKS GREAT.
Date published: 2011-12-22
  • 2016-02-07T06:26CST
  • co_hasreviews, tv_0, tr_21
  • loc_en_US, sid_370-350, PRD, sort_mostRecent
