HDMI Switch 3-Input 1-Output IR Compatible Supports 3D and 4K
Brand:|Part # 180-636
If you have more sources than your TV or audio/video receiver can handle, you need an HDMI selector—this one switches between three separate A/V components.
List Price$38.99
You Save24%
$29.76
Buy 10+$24.50
Part # 180-636
  • Works with the Easy IR Extender kit to provide forward and reverse path IR capability
  • Supports 3D and 4K video
  • Built-in HDMI extender transmits video over 100 feet
  • Small size fits almost anywhere
It seems as though you will always have more A/V sources than inputs on your TV or A/V receiver. This HDMI 3-input 1-output selector makes it easier than ever to expand your system without breaking the bank. Designed to HDMI 1.4 specification to support 3D and 4K video.
Built-in signal compensation enables the selector to be up to 20 meters from the source and 20 meters from the display (using 24 AWG cables). When used with the Easy IR Extender kit (sold separately), equipment can be controlled without installing additional wires. The Unique Backward-IR Channel allows you to control devices at the viewing location from the source equipment location with an additional Easy IR Extender kit. The small size of these splitter/extenders allows them to be placed almost anywhere.
Additional features: • Supports 3D and 4K video • Bandwidth: 2.22 Gbps per channel, 6.75 Gbps total • Supports full HD1080p 24fps @ 60Hz, 4K @ 24/30fps • Supports deep color 16 bit • Supports resolution up to 1920 x 1200 • Supports standard 24 bit color (RGB/YPbPr) and xvYCC deep color • Supports DTS-HD, TrueHD, LPCM7.1, AC3, DTS, and DSD audio formats.
  • Audio Input/OutputHDMI
  • Video Input/OutputHDMI
  • BrandParts Express
  • Part Number180-636
  • UPC844632094071
  • Product CategoryA/V Source Switchers
    (7 Reviews)
  • Weight1.15 lbs.
View similar products to the HDMI Switch 3-Input 1-Output IR Compatible Supports 3D and 4K
in the A/V Source Switchers product category.
