180-636_ALT_0
180-636_ALT_1
HDMI 3-Input 1-Output 3D Switch IR Compatible
If you have more sources than your TV or audio/video receiver can handle, you need an HDMI selector—this one switches between three separate A/V components.
  • Works with the Easy IR Extender kit to provide forward and reverse path IR capability
  • Supports 3D video
  • Built-in HDMI extender transmits video over 100 feet
  • Small size fits almost anywhere
180-636
Weight: 1.15 lbs.
IN STOCK
List Price$38.99
You Save24%
$29.76
Part # 180-636
It seems as though you will always have more A/V sources than inputs on your TV or A/V receiver. This HDMI 3-input 1-output selector makes it easier than ever to expand your system without breaking the bank. Designed to HDMI 1.4 specification to support 3D video.
Built-in signal compensation enables the selector to be up to 20 meters from the source and 20 meters from the display (using 24 AWG cables). When used with the Easy IR Extender kit (sold separately), equipment can be controlled without installing additional wires. The Unique Backward-IR Channel allows you to control devices at the viewing location from the source equipment location with an additional Easy IR Extender kit. The small size of these splitter/extenders allows them to be placed almost anywhere.
Additional features: • Supports 3D video • HDCP 1.2 compliant • Bandwidth: 2.22 Gbps per channel, 6.75 Gbps total • Supports full HD1080p 24fps, 60Hz • Supports deep color 36 bit • Supports resolution up to 1920 x 1200 • Supports standard 24 bit color (RGB/YPbPr) and xvYCC deep color • Supports DTS-HD, TrueHD, LPCM7.1, AC3, DTS, and DSD audio formats.
  • Audio Input/OutputHDMI
  • Video Input/OutputHDMI
  • BrandParts Express
  • Part Number180-636
  • UPC844632094071
  • Product CategoryA/V Source Switchers
    (6 Reviews)
  • Weight1.15 lbs.
View similar products to the HDMI 3-Input 1-Output 3D Switch IR Compatible
in the A/V Source Switchers product category.
HDMI 3-Input 1-Output 3D Switch IR Compatible is rated 4.1667 out of 5 by 6.
Rated 5 out of 5 by from Works like a charm!Installed HDMI cable in the ceiling/wall in 2006, worked well with 720dpi projector. Recently upgraded to 1080p and kept having drop-out, frame loss. Inserted this HDMI switch to replace an older one, circa 2006, and voila, perfect video wth the old cable. A lifesaver!
Date published: 2015-05-26
Rated 5 out of 5 by from It works great.This unit works as described. I'm not sure when it would even need the power adapter. (gets power from the HDMI feed cable.)Fast to switch video feeds with small button on unit or with the included remote. It will self detect when to switch inputs.Very nice.
Date published: 2014-04-11
Rated 1 out of 5 by from Did not work out of the boxIt did not work out of the box.  I returned it.....
Date published: 2013-12-22
Rated 5 out of 5 by from Does the job!In trying to simplify the connections to my entertainment system, I found this HDMI switch box to be exactly what I needed. What's even nicer is that I didn't even need to connect the power supply as it derives power from the HDMI cables thus eliminating one more connection. The switching is seemless between my cable box, Blu-ray and Apple TV module without distortion or loss of signal.If I had one wish, I would have liked to have seen connections for optical digital cables added to this box. Little did I know that the optical audio output on my flatscreen turns 'off' when HDMI is connected. It turns out to be a more common complaint with some brands of TV than I realized.So... now I have to purchase another switch box to handle the 5.1 audio to my surround sound system.
Date published: 2013-08-14
Rated 4 out of 5 by from Problem SolverWhen I wanted to get a Roku unit for my TV I found that the 2 HDMI ports on my TV were already used. My youngest son, my electronics expert, recommended that I get this part to solve the problem along with an HDMI cable to complete the installation. When the part arrived, with a little help from my expert, I was able to hook up the switch and the Roku within 30 mins. and I am now working on programming my Logitech remote to handle the new equipment.
Date published: 2012-06-24
Rated 5 out of 5 by from Great and works with 3D like advertisedAll of my AV equipment is located in another room from my new 3D TV. So purchasing multiple long HDMI cables (25ft) or upgrading my receiver to switch HDMI inputs was going to be expensive. This HDMI switch solved the problem and works great. We just watched a 3D movie last night and you'd never know it wasn't running directly off the BluRay player.I was even able to put an IR flasher from my IR repeater system on the switch and program my universal remote to change the HDMI inputs when running the macros. Now everything is running off a single remote.The size is really small so it's easy to locate in my A/V rack, but I had to use double-sided tape to hold it down. It's so small that multiple HDMI cables left it moving around and not stationary. With what I saved not having to upgrade other equipment, a roll of good double-sided tape was very affordable.Great product and a money saver for me!
Date published: 2012-01-14
  • 2015-07-28T07:17CST
  • bvseo_cps, prod_bvrr, vn_cps_3.1.5
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_180-636, PRD, sort_mostRecent
If i plug in a xbox and a dvr to this and want to switch back and forth can i switch between the two while they are still on or does the xbox have to be powered of to use the dvr vice versa
Asked by: Andregtable
This switch comes with a remote control so you can switch between the inputs as desired.
Answered by: PE Tom
Date published: 2015-02-02
I have an HDMI handshake issue with my Preamp. I have read in forums of a HDMI switch solving this issue. Can you elaborate, will it work?
Asked by: Terentellie
I really doubt that a simple switcher such as this product would cure any handshake problem you're experiencing. It would more likely be a bad hdmi cable, too long of a cable run, that kind of thing.
Answered by: Eric Chandler
Date published: 2014-09-24
My TV has only 1080i or 720p, will this device downscale the signal output when the input is 1080p such as blue-ray player?
Asked by: Gurumaster
No, it will not. You will still need to set the sources you are using to output signals that your TV can use. No big loss though. I know wouldn't want a $30 piece of equipment handling any scaling of my video signals, up or down.
Answered by: Travis Rysdam
Date published: 2013-09-07
Does it include a remote?
Asked by: maxbragado
yes. If you look at the pictures on the product page, there it is.
Answered by: Fanden
Date published: 2012-03-27
  • 2015-07-28T08:04CST
  • bvseo_cps, prod_bvqa, vn_cps_3.1.5
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_180-636, PRD, sort_recentQuestionsFirst
Customer projects that include: HDMI 3-Input 1-Output 3D Switch IR Compatible
