266-254_ALT_0
266-254_ALT_1
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA
Brand:|Part # 266-254
FMODs™ feature a 12 dB per octave crossover slope and are compatible with all RCA type input amps. Sold in pairs.
$25.90
Buy 4+$23.55
Part # 266-254
What is an FMOD™? The FMOD™ is an active crossover simulator. It is better than a much more expensive electronic crossover that requires power to operate. FMODs™ are packaged in pairs and can be combined with other FMODs™ to obtain bandpass ranges or with other types of crossovers to change the slope and crossover frequency point. FMODs™ feature a 12 dB per octave crossover slope and are compatible with all RCA type input amps...simply place the FMOD™ in-line with the patch cable running between the source (head unit) and the amplifier. 24kt gold over brass construction, 10 volts maximum RMS input. One-year manfacturer warranty. Made in the U.S.A.
  • Crossover TypeLow Pass
  • ConfigurationInline Line Level
  • BrandHarrison Labs
  • Part Number266-254
  • UPC848864007069
  • Product CategoryIn-Line Crossovers
  • Unit of MeasurePR
    (4 Reviews)
  • Weight0.0908 lbs.
View similar products to the Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA
in the In-Line Crossovers product category.
Harrison Labs FMOD Inline Crossover Pair 100 Hz Low Pass RCA is rated 4.25 out of 5 by 4.
Rated 5 out of 5 by from Does what you need it to do.I'm using this for in place of a 2 way crossover for my DJ Rig. works for sending low signals to my sub amp. Great alternative to a rack mount crossover. Saves weight, saves rack space, and $100.
Date published: 2013-11-12
Rated 5 out of 5 by from superb in all parametersI am a professional sound engineer. I am also a semi pro bassist. This simple passive component allows one to use a bass amp as a subwoofer. I also had an old 1 x15 bass cab lying around and a 150 watt mono power amp, turned that into a sub as well... 2 respectable seriously loud subwoofers for 25 bucks, that is value, period. the harrison F mods are probably the best bang for the buck cheap upgrades available, LOVE THEM....
Date published: 2009-11-25
Rated 2 out of 5 by from It choked out the highs, maybe too much.I was hoping this would eliminate the need for actual cross overs in my install. I feel the signal suffered a loss before the amp that was not limited to high frequencies. I knew this was a risk. I have eliminated them from my install and I am using another option right now. I will be trying them with another configuration and I hope they will work well then.I am not certain that my preamp output voltage is not the cause of the extra loss I feel I had.I have not given up on them yet.
Date published: 2009-04-15
Rated 5 out of 5 by from FMod high impedance crossoversI used the 100Hz FMod as a high impedance crossover ahead of one of our four 250W amps on the riverboat sound system. By using two in seriese I got ONLY base for our large speakers. We have eight others for mid/hi. The FMods worked well.
Date published: 2008-02-18
  • 2016-02-11T06:36CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_266-254, PRD, sort_mostRecent
