Hammond 274X Power Transformer
Brand:| Model: 274X
The 270 Series power transformers use the convenient 4 hole above chassis "X" type bell end mounts. Each unit features a 115 VAC, 60 Hz primary and two secondary filament windings, one 5.0V for tube rectifiers, plus a 6.3V for heater filaments. Leads are a minimum of 6" in length.
122-230
Weight: 4.655 lbs.
ORDER TODAY
Ships in 3-10 business days
$81.84
Part # 122-230
The 270 Series power transformers use the convenient 4 hole above chassis "X" type bell end mounts. Each unit features a 115 VAC, 60 Hz primary and two secondary filament windings, one 5.0V for tube rectifiers, plus a 6.3V for heater filaments. Leads are a minimum of 6" in length. Class A insulation (105ºC). These transformers are conservatively rated and CSA certified. VA: 138, Secondary RMS: 375-0-375, DC mA: 110, Fil. #1 Rectifier: 5.0V/3A, Fil. #2 Heater: 6.3V/5.0A CT.
  • BrandHammond Manufacturing
  • Model274X
  • Part Number122-230
  • UPC623980277004
  • Product CategoryPower Transformers
    (2 Reviews)
  • Weight4.655 lbs.
Hammond 274BX Power Transformer
Part # 122-235
View similar products to the Hammond 274X Power Transformer
in the Power Transformers product category.
Hammond 274X Power Transformer is rated 4.0 out of 5 by 2.
Rated 4 out of 5 by from Pretty Good for a Fender Clone ProjectI forgot to mention, if I were using EL34's, 6550's, KT88's, etc., I would definitely step up in size (VA rating) as the filament demand of those tubes would push this transformer too far in this case. This transformer would be perfect for a 6V6 project, however the B+ voltage is too high even with a tube rectifier (I tried it anyway) for 6V6's. So pretty much stick with 6L6's with this one.
Date published: 2012-03-04
Rated 4 out of 5 by from Pretty Good for Fender Clone ProjectUsed this as the power trans. for a 1968 Fender Pro Reverb clone project. Very good transformer, good quality. I have it run basically a little more than rated output, 40mA push pull=80mA total idle, (1.5x80mA=120mA, rated output at max musical signal), plus filaments. It is holding up well, runs a bit warm but seems to be very dependable so far.
Date published: 2011-02-17
Customer projects that include: Hammond 274X Power Transformer
