292-408_ALT_0
292-408_ALT_1
292-408_ALT_2
GRS 8PF-8 8" Paper Cone Foam Surround Woofer
Brand:|Model: 8PF-8|Part # 292-408
If you are looking for a low-cost, high-performance 8" replacement speaker, check out the GRS 8PF-8!
List Price$13.99
You Save20%
$11.25
Buy 4+$9.00
Part # 292-408
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
If you are looking for a low-cost, high-performance 8" replacement speaker, check out the GRS 8PF-8! Thanks to their carefully optimized parameters, GRS 8PF-8 8" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
  • Nominal Diameter8"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response55 to 6,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)51 Hz
  • DC Resistance (Re)7.59 ohms
  • Voice Coil Inductance (Le)1.11 mH
  • Mechanical Q (Qms)4.58
  • Electromagnetic Q (Qes)1.17
  • Total Q (Qts)0.93
  • Compliance Equivalent Volume (Vas)0.95 ft.³
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialPaper
  • Magnet MaterialFerrite
  • Overall Outside Diameter8"
  • Baffle Cutout Diameter7.32"
  • Depth3.44"
  • # Mounting Holes4
  • Sealed Volume1.3 ft.³
  • Sealed F354 Hz
  • Vented Volume4.91 ft.³
  • Vented F330 Hz
  • BrandGRS
  • Model8PF-8
  • Part Number292-408
  • UPC844632088476
  • Product CategoryWoofers
    (29 Reviews)
  • Weight2.95 lbs.
View similar products to the GRS 8PF-8 8" Paper Cone Foam Surround Woofer
