GRS 6PF-8 6-1/2" Paper Cone Foam Surround Woofer
Brand:|Model: 6PF-8|Part # 292-406
All the sound you need, and without spending a bundle! The GRS 6PF-8 paper cone 6" woofer is the answer to your replacement speaker needs.
List Price$13.99
You Save26%
Buy 4+$8.30
Part # 292-406
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
All the sound you need thanks to their carefully optimized parameters, the GRS 6PF-8 6-1/2" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)90 Watts
  • Power Handling (max)180 Watts
  • Impedance8 ohms
  • Frequency Response70 to 8,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)82 Hz
  • DC Resistance (Re)7.59 ohms
  • Voice Coil Inductance (Le)1.09 mH
  • Mechanical Q (Qms)3.67
  • Electromagnetic Q (Qes)1.3
  • Total Q (Qts)0.95
  • Compliance Equivalent Volume (Vas)0.25 ft.³
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.625"
  • Depth3.0625"
  • # Mounting Holes4
  • Sealed Volume0.34 ft.³
  • Sealed F386 Hz
  • Vented Volume1.35 ft.³
  • Vented F347 Hz
  • BrandGRS
  • Model6PF-8
  • Part Number292-406
  • UPC844632088469
  • Product CategoryWoofers
    (11 Reviews)
  • Weight2.9 lbs.
View similar products to the GRS 6PF-8 6-1/2" Paper Cone Foam Surround Woofer
