292-415_ALT_0
292-415_ALT_1
292-415_ALT_2
GRS 15PF-8 15" Paper Cone Foam Surround Woofer
Brand:|Model: 15PF-8|Part # 292-415
The GRS 15PR-8 speaker is the best choice you can make if you need to replace a worn out, blown 15" woofer.
List Price$38.99
You Save21%
$30.88
Buy 4+$24.70
Part # 292-415
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
The GRS 15PR-8 speaker is the best choice you can make if you need to replace a worn out, blown 15" woofer. Thanks to its carefully optimized parameters, the GRS 15PF-8 15" poly-laminated paper cone woofer provides a high degree of compatibility when used as a replacement speaker—it also delivers excellent performance in your new projects, too.
  • Nominal Diameter15"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance8 ohms
  • Frequency Response25 to 4,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)29 Hz
  • DC Resistance (Re)7.21 ohms
  • Voice Coil Inductance (Le)1.14 mH
  • Mechanical Q (Qms)5.09
  • Electromagnetic Q (Qes)1.92
  • Total Q (Qts)1.39
  • Compliance Equivalent Volume (Vas)9.39 ft.³
  • Maximum Linear Excursion (Xmax)4 mm
  • Cone MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.125"
  • Baffle Cutout Diameter14"
  • Depth5.44"
  • # Mounting Holes8
  • Sealed Volume5.64 ft.³
  • Sealed F329 Hz
  • Vented Volume106 ft.³
  • Vented F314 Hz
  • BrandGRS
  • Model15PF-8
  • Part Number292-415
  • UPC844632088506
  • Product CategoryWoofers
    (21 Reviews)
  • Weight7.55 lbs.
View similar products to the GRS 15PF-8 15" Paper Cone Foam Surround Woofer
