292-412_ALT_0
292-412_ALT_1
292-412_ALT_2
GRS 12PF-8 12" Paper Cone Foam Surround Woofer
Brand:|Model: 12PF-8|Part # 292-412
GRS 12PF-8 12" poly-laminated paper cone woofers are perfect for use in sealed-box home theater and music systems.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
List Price$19.99
You Save21%
$15.88
Buy 4+$12.70
Part # 292-412
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
GRS 12PF-8 12" poly-laminated paper cone woofers are perfect for use in sealed-box home theater and music systems. Thanks to their carefully optimized parameters, GRS 12PF-8 12" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
  • Nominal Diameter12"
  • Power Handling (RMS)120 Watts
  • Power Handling (max)240 Watts
  • Impedance8 ohms
  • Frequency Response35 to 5,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)35 Hz
  • DC Resistance (Re)7.56 ohms
  • Voice Coil Inductance (Le)1.15 mH
  • Mechanical Q (Qms)5.97
  • Electromagnetic Q (Qes)2.08
  • Total Q (Qts)1.54
  • Compliance Equivalent Volume (Vas)5.28 ft.³
  • Maximum Linear Excursion (Xmax)3.5 mm
  • Cone MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter12"
  • Baffle Cutout Diameter11.0625"
  • Depth4.69"
  • # Mounting Holes6
  • Sealed Volume2.92 ft.³
  • Sealed F340 Hz
  • Vented Volume73 ft.³
  • Vented F319 Hz
  • BrandGRS
  • Model12PF-8
  • Part Number292-412
  • UPC844632088490
  • Product CategoryWoofers
    (28 Reviews)
  • Weight3.85 lbs.
View similar products to the GRS 12PF-8 12" Paper Cone Foam Surround Woofer
