292-410_ALT_0
292-410_ALT_1
292-410_ALT_2
GRS 10PF-8 10" Paper Cone Foam Surround Woofer
Brand:|Model: 10PF-8|Part # 292-410
GRS 10PF-8 10" paper cone woofers are ideal replacement speakers for use in sealed-box loudspeaker systems in almost any application.
List Price$18.99
You Save29%
$13.46
Buy 4+$10.76
Part # 292-410
  • Perfect for use in sealed-box home theater and music systems
  • Poly-laminated paper cone, treated foam surround, and polymer dust cap
  • Smooth frequency response with minimal cone breakup
GRS 10PF-8 10" paper cone woofers are ideal replacement speakers for use in sealed-box loudspeaker systems in almost any application. Thanks to their carefully optimized parameters, GRS 10PF-8 10" poly-laminated paper cone woofers offer a high degree of compatibility when used as replacement speakers—they also provide excellent performance in new projects, too.
  • Nominal Diameter10"
  • Power Handling (RMS)110 Watts
  • Power Handling (max)220 Watts
  • Impedance8 ohms
  • Frequency Response40 to 5,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1.5"
  • Resonant Frequency (Fs)43 Hz
  • DC Resistance (Re)7.56 ohms
  • Voice Coil Inductance (Le)1.19 mH
  • Mechanical Q (Qms)5.32
  • Electromagnetic Q (Qes)1.66
  • Total Q (Qts)1.27
  • Compliance Equivalent Volume (Vas)2.27 ft.³
  • Maximum Linear Excursion (Xmax)3 mm
  • Cone MaterialTreated Paper
  • Magnet MaterialFerrite
  • Overall Outside Diameter10"
  • Baffle Cutout Diameter9.25"
  • Depth4.125"
  • # Mounting Holes4
  • Sealed Volume1.87 ft.³
  • Sealed F345 Hz
  • Vented Volume21.49 ft.³
  • Vented F324 Hz
  • BrandGRS
  • Model10PF-8
  • Part Number292-410
  • UPC844632088483
  • Product CategoryWoofers
    (42 Reviews)
  • Weight3.35 lbs.
View similar products to the GRS 10PF-8 10" Paper Cone Foam Surround Woofer
