Goldwood TR12D 12" Dual Sealed Box Speaker Cabinet
Brand:|Model: TR12D|Part # 260-648
Goldwood truck boxes are CNC cut using 3/4" MDF and glued air tight, covered in black polyester carpet. Includes gold input terminals. For use with two 12" woofers. Slanted back design.
- Order Soon - Only 3 Left In Stock
List Price$97.99
You Save27%
$71.50
Part # 260-648
  • 3/4" MDF sealed enclosure
  • Black carpet covering
  • Gold terminal posts
  • Sold individually
Goldwood truck boxes are CNC cut using 3/4" MDF and glued air tight, producing a strong, tight, rock-solid box. High quality black polyester carpet and audiophile-grade gold input terminals put the finishing touch on these boxes. For use with two 12" woofers. Slanted back design.
Specifications: • Dimensions: 13" H x 32" W x 15-1/2" (12" Top) D • Approximately 1.25 cu. ft. per side (2.5 cu.ft. total) • Cutout: 11" Diameter • Sold individually.
  • BrandGoldwood
  • ModelTR12D
  • Part Number260-648
  • UPC643420413335
  • Product CategoryEmpty Car Speaker Boxes
    (8 Reviews)
  • Weight35 lbs.
View similar products to the Goldwood TR12D 12" Dual Sealed Box Speaker Cabinet
in the Empty Car Speaker Boxes product category.
Goldwood TR12D 12" Dual Sealed Box Speaker Cabinet is rated 4.75 out of 5 by 8.
Rated 5 out of 5 by from Pleasent surpriseIncredible deal! Carpet is OK, and the terminals are screw-down 4-way. I am running a pair of the Classic Dayton's. While I've certainly heard better, these are deep and solid for a fraction of the potential cost!
Date published: 2013-10-05
Rated 5 out of 5 by from Sub woofer cab reviewI used these empty cabs (2 -2x12s) in a rather unorthodox manner. I loaded them with high wattage Eminence Man O War guitar speakers. I dampened the interior walls with polyfill batting to cull the empty box rumble and distortions that creates. Although each speaker is isolated in its own sealed side, the results were spectacular. I made these 2x12 cabs for less than half what one would have cost and they preform exceptionally at 240watt RMS capability. I had no problems screw mounting the speaker using pilot holes and installed metal speaker grill protects with the larger bolt prong in the wood retainers. Turned out better than I expected. Sorry I have no pics at the moment.
Date published: 2013-09-16
Rated 5 out of 5 by from great sub boxi put 2 12inch lanzar max 12 in this box sounds awesome i have a 1200 watt hifonics amp for this for the price i love it .the only thing i would like if the inside speaker connectors where a little more stiffer so it doesnt bend as much but it really isnt a problem well worth the money
Date published: 2012-03-07
Rated 5 out of 5 by from Nice box. SturdyNice and solid with spring connectors.Sealed nice and has the typical black carpet glued on.I had concern about the packaging with no crush room or packaging inside knowing that UPS has a "3ft drop on corner" requirement. But there was no damage and I think the box could have survived it any way. They dont try to make money off of shipping costs either. I WILL buy more from PartsXpress.
Date published: 2009-04-15
Rated 4 out of 5 by from Decent box for the priceThis is a heavy box constructed of MDF which is a hybrid recycled wood like material. The box is sturdy and well caulked. The only negative is the outer applied carpet material that easily rips at the edges. If you are taking this box in and out of a car purchase some steel corner protectors.
Date published: 2009-03-09
Rated 4 out of 5 by from Great box for the moneyThis is the first box I have ever bought.I've always built my own because I either needed something custom or the enclosures available just weren't built tough enough for my liking.Being a family man now spare time is almost nonexistent so I thought that I would take a chance on this enclosure and I was very pleasently surprised.It is very well constructed,carpeted nicely,and even has some good quality binding post terminals to boot.If you just need a standard sealed 12 inch sub box you really can't go wrong with this one.You can't even buy the materials to make a good box for what this one cost.The only real gripes I have about it are that the woofer holes could be slightly larger as it is hard to fit a cast frame woofer into those openings(took some filing) and that the hook up terminals inside the box are kind of flimsy.All in all though it is a great box.
Date published: 2009-01-30
  • 2016-02-10T06:48CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_260-648, PRD, sort_mostRecent
