Goldwood GW-S525/8 5-1/4" Poly Cone Woofer 8 Ohm
Brand:|Model: GW-S525/8|Part # 290-302
These silver polymer cone woofers feature a cosmetic stamped steel frame, vented and bumped back plate, and high-quality rubber surround. The relatively shallow profile, polymer construction, and T/S parameters make them great for sealed, free air, or in wall use.
$14.38
Buy 4+$12.47
Part # 290-302
  • Poly cone and rubber surround is ideal for harsh environments
  • Vented pole piece improves power handling
  • Cosmetic frame looks good without countersinking
  • Bumped back plate increases mechanical excursion
  • Nominal Diameter5-1/2"
  • Power Handling (RMS)70 Watts
  • Power Handling (max)130 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,500 Hz
  • Sensitivity84.7 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Magnet Weight15 oz.
  • Resonant Frequency (Fs)81.1 Hz
  • DC Resistance (Re)7 ohms
  • Voice Coil Inductance (Le)0.4 mH
  • Mechanical Q (Qms)2.87
  • Electromagnetic Q (Qes)1.18
  • Total Q (Qts)0.84
  • Compliance Equivalent Volume (Vas)0.13 ft.³
  • Mechanical Compliance of Suspension (Cms)0.4 mm/N
  • BL Product (BL)5.41 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.7g
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)82.29 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.625"
  • Baffle Cutout Diameter4.56"
  • Depth2.5"
  • # Mounting Holes4
  • Sealed Volume0.21 ft.³
  • Sealed F388 Hz
  • Vented Volume0.55 ft.³
  • Vented F348 Hz
  • BrandGoldwood
  • ModelGW-S525/8
  • Part Number290-302
  • UPC643420100501
  • Product CategoryWoofers
    (12 Reviews)
  • Weight1.6 lbs.
View similar products to the Goldwood GW-S525/8 5-1/4" Poly Cone Woofer 8 Ohm
