Goldwood GW-S525/4 5-1/4" Poly Cone Woofer 4 Ohm
Brand:|Model: GW-S525/4|Part # 290-301
These silver polymer cone woofers feature a cosmetic stamped steel frame, vented and bumped back plate, and high-quality rubber surround. The relatively shallow profile, polymer construction, and T/S parameters make them great for sealed, free air, or in wall use.
$14.38
Buy 4+$12.47
Part # 290-301
  • Cosmetic frame looks good without countersinking
  • Bumped back plate increases mechanical excursion
  • Poly cone and rubber surround is ideal for harsh environments
  • Vented pole piece improves power handling
  • Nominal Diameter5-1/2"
  • Power Handling (RMS)70 Watts
  • Power Handling (max)130 Watts
  • Impedance4 ohms
  • Frequency Response50 to 5,500 Hz
  • Sensitivity86.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Magnet Weight15 oz.
  • Resonant Frequency (Fs)72.9 Hz
  • DC Resistance (Re)3.6 ohms
  • Voice Coil Inductance (Le)0.3 mH
  • Mechanical Q (Qms)3.79
  • Electromagnetic Q (Qes)1.15
  • Total Q (Qts)0.88
  • Compliance Equivalent Volume (Vas)0.15 ft.³
  • Mechanical Compliance of Suspension (Cms)0.45 mm/N
  • BL Product (BL)3.9 Tm
  • Diaphragm Mass Inc. Airload (Mms)10.5g
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)82.29 cm²
  • Cone MaterialPoly
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.6875"
  • Baffle Cutout Diameter4.4375"
  • Depth2.25"
  • # Mounting Holes4
  • Sealed Volume0.23 ft.³
  • Sealed F377 Hz
  • Vented Volume0.7 ft.³
  • Vented F342 Hz
  • BrandGoldwood
  • ModelGW-S525/4
  • Part Number290-301
  • UPC643420100495
  • Product CategoryWoofers
    (13 Reviews)
  • Weight1.6 lbs.
View similar products to the Goldwood GW-S525/4 5-1/4" Poly Cone Woofer 4 Ohm
