Goldwood GW-205/8S 5-1/4" Shielded Poly Woofer 8 Ohm
Brand:|Model: GW-205/8S|Part # 290-376
The poly-laminated paper cone, treated foam surround, and polymer dustcap give these drivers a very smooth frequency response with minimal cone breakup. The shielded magnet structure of this driver makes it great for A/V applications.
$12.90
Buy 4+$11.85
Part # 290-376
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)70 Watts
  • Power Handling (max)130 Watts
  • Impedance8 ohms
  • Frequency Response62 to 12,000 Hz
  • Sensitivity87 dB 1W/1m
  • Voice Coil Diameter1"
  • Magnet Weight16 oz.
  • Resonant Frequency (Fs)86.1 Hz
  • DC Resistance (Re)7.1 ohms
  • Voice Coil Inductance (Le)0.4 mH
  • Mechanical Q (Qms)3.18
  • Electromagnetic Q (Qes)1.1
  • Total Q (Qts)0.82
  • Compliance Equivalent Volume (Vas)0.18 ft.³
  • Mechanical Compliance of Suspension (Cms)0.38 mm/N
  • BL Product (BL)5.62 Tm
  • Diaphragm Mass Inc. Airload (Mms)9g
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)96.77 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.25"
  • Baffle Cutout Diameter4.75"
  • Depth3.125"
  • # Mounting Holes4
  • Sealed Volume0.3 ft.³
  • Sealed F394 Hz
  • Vented Volume0.7 ft.³
  • Vented F351 Hz
  • BrandGoldwood
  • ModelGW-205/8S
  • Part Number290-376
  • UPC643420100389
  • Product CategoryWoofers
    (25 Reviews)
  • Weight3 lbs.
View similar products to the Goldwood GW-205/8S 5-1/4" Shielded Poly Woofer 8 Ohm
