Goldwood GW-204/4S 4" Shielded Poly Woofer 4 Ohm
Brand:|Model: GW-204/4S|Part # 290-370
The poly-laminated paper cone, treated foam surround, and polymer dustcap give these drivers a very smooth frequency response with minimal cone breakup. The shielded magnet structure of this driver makes it great for A/V applications.
$11.28
Buy 4+$10.19
Part # 290-370
  • Nominal Diameter4-1/2"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)70 Watts
  • Impedance4 ohms
  • Frequency Response70 to 13,000 Hz
  • Sensitivity86 dB 1W/1m
  • Voice Coil Diameter1"
  • Magnet Weight10 oz.
  • Resonant Frequency (Fs)139.8 Hz
  • DC Resistance (Re)3.7 ohms
  • Voice Coil Inductance (Le)0.1 mH
  • Mechanical Q (Qms)7.19
  • Electromagnetic Q (Qes)2.2
  • Total Q (Qts)1.69
  • Compliance Equivalent Volume (Vas)0.04 ft.³
  • Mechanical Compliance of Suspension (Cms)0.24 mm/N
  • BL Product (BL)2.84 Tm
  • Diaphragm Mass Inc. Airload (Mms)5.2g
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Surface Area of Cone (Sd)53.52 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialFoam
  • Magnet MaterialFerrite
  • Overall Outside Diameter5" outside edge to edge, 4.15"
  • Baffle Cutout Diameter4"
  • Depth2.5625"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3161 Hz
  • Vented Volume0.66 ft.³
  • Vented F371 Hz
  • BrandGoldwood
  • ModelGW-204/4S
  • Part Number290-370
  • UPC643420100358
  • Product CategoryWoofers
    (14 Reviews)
  • Weight1.4 lbs.
View similar products to the Goldwood GW-204/4S 4" Shielded Poly Woofer 4 Ohm
