290-382_ALT_0
290-382_ALT_1
Goldwood GW-1258 12" Pro Woofer
Brand:| Model: GW-1258
Designed for sound reinforcement systems, lead guitar and rhythm guitars, practice amplifiers for bass guitar, stage monitors, and vocal PA systems. They feature accordion paper surround, poly laminated paper cone, and a vented pole piece.
290-382
Weight: 9.6 lbs.
IN STOCK
$52.38
Buy 4-up$48.30
Part # 290-382
  • Nominal Diameter12"
  • Power Handling (RMS)190 Watts
  • Power Handling (max)290 Watts
  • Impedance8 ohms
  • Frequency Response33 to 5,000 Hz
  • Sensitivity97 dB 1W/1m
  • Voice Coil Diameter2.5"
  • Magnet Weight50 oz.
  • Resonant Frequency (Fs)41.5 Hz
  • DC Resistance (Re)5.3 ohms
  • Voice Coil Inductance (Le)0.06 mH
  • Mechanical Q (Qms)3.1
  • Electromagnetic Q (Qes)0.56
  • Total Q (Qts)0.48
  • Compliance Equivalent Volume (Vas)5.58 ft.³
  • Mechanical Compliance of Suspension (Cms)0.33 mm/N
  • BL Product (BL)10.44 Tm
  • Maximum Linear Excursion (Xmax)2 mm
  • Surface Area of Cone (Sd)585.6 cm²
  • Cone MaterialPaper
  • Surround MaterialPaper
  • Overall Outside Diameter12.125"
  • Baffle Cutout Diameter10.875"
  • Depth5.125"
  • # Mounting Holes8
  • Sealed Volume2.35 ft.³
  • Sealed F373 Hz
  • Vented Volume7.88 ft.³
  • Vented F339 Hz
  • * Enclosure volume/F3s based on BassBox "optimum" calculations-
Optimum Cabinet Size *
  • Sealed F373 Hz
  • Vented F339 Hz
  • BrandGoldwood
  • ModelGW-1258
  • Part Number290-382
  • UPC643420100099
  • Product CategoryWoofers, Subwoofers & Midrange Speakers
    (12 Reviews)
  • Weight9.6 lbs.
View similar products to the Goldwood GW-1258 12" Pro Woofer
in the Woofers, Subwoofers & Midrange Speakers product category.
Goldwood GW-1258 12" Pro Woofer is rated 4.25 out of 5 by 12.
Rated 5 out of 5 by from EV ReplacementsI bought a pair of these a year ago to replace those in my EV PA speakers. I bought a set of Eminence ASD 1001 1" titanium horn drivers to match up with them.I use them six nights a week on the beach. The speakers have done a beautiful job while taking massive amounts of punishment as they suck in salt air. They have not let me down.I did have to replace one of the Eminence horn drivers but that was caused by a high frequency blast of feedback that could melt steel.Great value!
Date published: 2013-08-12
Rated 4 out of 5 by from Good Budget SpeakerI used this woofer in an Econowave design in an 3.3 cu ft. sealed box. I used the standard high efficiency crossover with the Selenium d220ti tweeter and pyle waveguide. This has worked well for some good sounds around the pool for the summer. Not the lowest bass but good output for most music. One of the woofers came in with a voice coil rub but PE was good in the return process. I would recommend this setup for a cheap high efficiency econowave project.
Rated 5 out of 5 by from Excellent Guitar SpeakerI used this speaker as a replacement for a Celestion G12T-75 in one of my JJ powered, all tube 40 watt Guitar Combo Amp's, and what a difference! This speaker sounds way better than the stock Celestion... Tight and Bright!
Date published: 2014-02-14
Rated 2 out of 5 by from Terrible as a guiitar speakerMakes a terrible guitar speaker, should've known it from the specs. Resonance is way too low, cone is reinforced, voiced terribly for guitar. Just avoid this if you're thinking about using it for guitar
Date published: 2013-10-06
Rated 4 out of 5 by from Well worth a try as a guitar/keyboard wooferThis is a strange and interesting one. I haven't actually played with it it was damaged during delivery. The damage is rather odd the edge of the basket was dented a bit by an obvious drop since it left an imprint of the inside of the box. The factory box is very flimsy; just thin cardboard with out any internal supports of packing braces, the driver just sits there in a plastic bag and is not secured by anything.The driver it self is indeed rather odd, it's a vented pole piece with a strong 50oz magnet but the basket is increasingly thin, soft stamped metal. Spider/cone look good, the dust cap is vented straight through the voice coil and out the magnet, so VC heating should not be a problem in sealed boxes under continues load. Even I haven't got to testing just by looking at it I would guess that this is an OEM based driver with possible intended use in pro guitar/keyboard cabinets. My best bet would be on sealed, powered guitar cabinets (about 150 watts RMS). I don't think this one would properly take 300 RMS, but since I haven't actually ran it it's only a guess. If I was putting together a guitar cabinet I would have exchanged the damaged one for a fresh one because there is definitely something special about this driver. Everything about it except the soft basket is clearly intended for pro use, and maybe in its intended application the rigid basket is not needed and a soft one simply lowers the manufacturing cost, but since I was planning on trying it as a hard driven mid bass reinforcement woofer, because of the soft basket I would have returned it even if it was not damaged. Yet again, if anybody is looking for a rather promising guitar/keyboard woofer give it a try, the price is definitely right and I would not at all be surprised if a number of big brand names in pro audio are using these as their OEMs.
Date published: 2014-03-15
Rated 5 out of 5 by from Great for the priceI've ordered 4 of theses all togetherNever any problemsGood bang for the buck
Date published: 2014-02-12
This woofer has a paper surround. Will it last a while or should I be looking for woofers with cloth surrounds?
Asked by: Minimus7
This uses a treated paper surround so it will last as long as the woofer assuming its not abused. We have sold this model for many years and I have not had a single call regarding a surround failure.
Date published: 2013-09-17
Customer projects that include: Goldwood GW-1258 12" Pro Woofer
