Goldwood GT-510 1" Soft Dome Tweeter
Brand:|Model: GT-510|Part # 270-176
Goldwood's 1" GT-510 soft, silk dome tweeter is great for use as a replacement high frequency driver. It's great bang-for-the-buck perfomance shines in budget constrained speaker designs!
$11.86
Buy 4+$10.53
Part # 270-176
  • Relatively flat frequency response from 2,000 to 20,000 Hz
  • Impressive 50 watt RMS power handling
  • 1" silk dome delivers natural sound
  • Semi horn loaded design controls dispersion and improves effeciency
Choose Goldwood's 1" GT-510 soft, silk dome tweeter for use as a replacement high frequency driver. An 8-ohm impedance makes it compatible with most speakers, and it's great bang-for-the-buck perfomance shines in budget-constrained speaker designs!
  • Tweeter TypeSoft Dome
  • Cone / Dome Diameter1"
  • Impedance8 ohms
  • Power Handling (RMS)50 Watts
  • Frequency Response3,000 to 20,000 Hz
  • Sensitivity90 dB 1W/1m
  • Resonant Frequency (Fs)1,300 Hz
  • Overall Outside Diameter4"
  • Cutout Diameter2.88"
  • Depth1.25"
  • BrandGoldwood
  • ModelGT-510
  • Part Number270-176
  • UPC643420500011
  • Product CategoryTweeters
    (33 Reviews)
  • Weight0.8 lbs.
View similar products to the Goldwood GT-510 1" Soft Dome Tweeter
in the Tweeters product category.
Goldwood GT-510 1" Soft Dome Tweeter is rated 4.5152 out of 5 by 33.
Rated 4 out of 5 by from surprisedReplaced a Polk unit. The Goldwood was so efficient and loud that I matched the other as well. Result was much needed clarity to a normally muddy system. Consider them a upgrade.
Date published: 2015-10-17
Rated 4 out of 5 by from Sound goodI put these in an old Kenwood speaker box 2 way, where the speakers were pretty much blown. One speaker still worked amazingly (being 30-40 years old) so I used these as the tweeters, and they sound good. No complaints.
Date published: 2015-04-03
Rated 1 out of 5 by from not so greatit just dissapoint me, ill not use this tweeter... its a pitty
Date published: 2015-02-15
Rated 4 out of 5 by from I'm just shaking my head....I'm kind of shocked that a ten dollar tweeter sounds this good. I always used European brands in the past and these are just great.
Date published: 2015-01-18
Rated 5 out of 5 by from sounds greatNever thought an inexpensive speaker could sound so good. Seem like a great quality built product.
Date published: 2015-01-17
Rated 5 out of 5 by from Great Up Grade For DLK Model 2'sHaapy I gave this a try, because i was never really happy with the stock CTS Tweeter on this model.Blends well with the stock drivers, with a very smooth and detailed response, and added air. Efficency is right on target with stock twweter.These aren't bright by any means but give the Model 2's just enough added detail to make them much more listenable, and remove the veiling and dryness of the stock tweeter, without being harsh.What more could you ask for, especially at this price?A real "hidden gem".
Date published: 2014-11-24
  • 2016-02-12T06:27CST
  • co_hasreviews, tv_0, tr_33
  • loc_en_US, sid_270-176, PRD, sort_mostRecent
What is the thickness of the mounting flange?
Asked by: SLB84
This flange is 1/4 inch thick.
Answered by: Chrisf
Date published: 2016-01-29
I really like these tweeter. They sound great. But the problem is ghat i like to listen to my music really lond. I just bought these after i blow the other pair out. My question what do you recommend on what kind of tweeters to so i dont blow them again?
Asked by: Epic
Date published: 2015-11-11
i need to cross this tweeter at 4000 Hz, which capacitor should i use? Also what coil should i use to low pass a woofer at 4000 Hz?
Asked by: tluoma
A crossover at 4,000 Hz still needs to be second order which would be a 3.5uF cap and a .45 mH coil. If you only want to use a cap, it will need to be a 3.3 uF for a safe crossover point of about 6kHz. An 8 ohm woofer at 4kHz needs a 0.25 mH coil.
Date published: 2015-09-29
what capacitor would be desired to cross this tweeter at 2000 Hz?
Asked by: Tyler2015
I would not recommend crossing this any lower than 3kHz, and I would still use a second order filter instead of just a cap. For this, I would use a 4.7 uF cap and a 0.6 mH coil.
Date published: 2015-09-25
What would be the best Electrolytic Capacitor to wire inline with this? will be building a 2 way box with the Goldwood GW-206/8 woofer. no crossover for the woofer.
Asked by: Brad79
I would recommend a 3.3 uF cap for this application.http://www.parts-express.com/33uf-100v-electrolytic-non-polarized-crossover-capacitor--027-328
Date published: 2015-09-14
I have the.Dayton Audio XO3W-375/3K 3-Way Speaker Crossover, would you recommend this tweeter or the dayton audio dc28ft-8 11/8 silk dome truncated tweeter?
Asked by: Epic
Either of these tweeters will work with this crossover, unfortunately I cannot say which would be "best".
Date published: 2015-06-12
  • 2016-02-12T06:53CST
  • co_hasquestionsanswers, tq_15
  • loc_en_US, sid_270-176, PRD, sort_recentQuestionsFirst
