Goldwood GT-25 4" Cone Tweeter
Brand:| Model: GT-25
This tweeter features a hard paper cone, treated paper surround, and black aluminum dust cap. Flat high frequency response to 20,000 Hz.
270-018
Weight: 0.6204 lbs.
IN STOCK
$6.11
Buy 4-up$5.48
Part # 270-018
This tweeter features a hard paper cone, treated paper surround, and metal dust cap. Flat high frequency response to 20,000 Hz.
  • Tweeter TypePaper Cone
  • Cone / Dome Diameter3"
  • Impedance8 ohms
  • Power Handling (RMS)35 Watts
  • Frequency Response3,000 to 20,000 Hz
  • Sensitivity90 dB 1W/1m
  • Resonant Frequency (Fs)1,500 Hz
  • Overall Outside Diameter4"
  • Cutout Diameter3.125"
  • Depth1"
  • BrandGoldwood
  • ModelGT-25
  • Part Number270-018
  • UPC643420500141
  • Product CategoryTweeters
    (52 Reviews)
  • Weight0.6204 lbs.
View similar products to the Goldwood GT-25 4" Cone Tweeter
in the Tweeters product category.
Goldwood GT-25 4" Cone Tweeter is rated 4.1154 out of 5 by 52.
Rated 5 out of 5 by from Drop-in fit.Bought a pair of these to replace the blown tweeters in some KLH 1555s that my son had. They were never great sounding speakers (mostly just loud) but these new tweeters really opened up the sound, and now they're at least "listenable". Can't beat the price, either.
Date published: 2014-12-10
Rated 5 out of 5 by from NOSGood new old sound, good at strings, quartet and vocal.
Date published: 2014-09-25
Rated 5 out of 5 by from Best Paper Cone Tweeter I Have HeardPaper cone speakers are the best, all things considered. Low Cost, and Great Sound. What more can you ask for.Also, I paired these tweeter with a GRS 5SBM-8 5" for the Midrange and I couldn't be happier
Date published: 2014-09-10
Rated 5 out of 5 by from Perfect drop in replacement in KLH9150AKThese are an exact replacement for the cone tweeter on the KLH 9150AK speakers. The only change I made was to bend the wire lugs and I soldered the wires to them rather than go find the proper sized connection fittings.
Date published: 2014-08-28
Rated 5 out of 5 by from Good basic, affordable tweeterI bought this two weeks ago, and I'm glad I did....I combined it with the GRS 8PR-8 woofer and PE 260-174 crossover, to build a good sounding pair of two way tower speakers.Note: the overall diameter of these tweeters is 4", not 1.06". And the cutout diameter listed is too small. I used a 3 1/8" hole saw, and they fit perfectly.
Date published: 2014-07-25
Rated 5 out of 5 by from Great For ReplacementsUsed this in my MCS 3-ways in the "midrange" with a 4.7uF JB cap and it sounds better than the original. Solidly built and does have a warm aura to it. However, I didn't realize the tiny black circle on it was sticky, so I got some sawdust on it that I couldn't really get completely off - if you're a newbie like me remember this.
Date published: 2014-07-17
  • 2015-03-03T06:34CST
  • co_hasreviews, tv_0, tr_52
  • loc_en_US, sid_270-018, PRD, sort_mostRecent
I'm replacing a tweet that covers an existing 3-1/2" dia. hole in the cabinet. Will this one cover that opening? The screw holes need to exceed this dia. by an appropriate dim. Say by 1/2"?
Asked by: LL2COOL
The mounting holes on this tweeter are only 3-5/8" on center, so they will probably not clear the mounting hole enough. You might want to look at our Dayton DC28F tweeter, which will fit that cutout and has mounting holes are just shy of 4" on center.http://www.parts-express.com/dayton-audio-dc28f-8-1-1-8-silk-dome-tweeter--275-070
Date published: 2015-01-19
Would these go well as replacements for the tweeters in my Nova-7b's? Or should I use the Phenolic Ring Tweeters?
Asked by: Sammyljk
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2014-11-19
What size caps do I need for a 3 way speaker set up. It has one woofer Two midrange and two tweeters, I have replace them , woofer GW210/8, mid GM85/5, GT25, So how many caps do I need as a crossover
Asked by: Stefan57
Date published: 2014-09-09
I have replace speaker in a off brand speaker cabinet it is a 3 way , with  one.Woofer 2 midrange and 2 tweeters what size cap do I need, I  have a set  caps 2.2 and 10 uf  Replace with gm85/5 and Gwen 210/8 and Gt25
Asked by: Stefan57
Date published: 2014-09-08
Hello. What is the center-to-center diagonal measurement between the mounting screws? I have a 3" cut-out and the existing screw holes are 3 3/4" apart diagonally. Thanks
Asked by: RickMartin
The screw holes on this tweeter are 3-1/2" on center when measured across the cone.
Date published: 2014-09-03
With the only spec being Fs, is there any way to get the component values to get the resonance/impedance peak out?
Asked by: ivandezande
Date published: 2014-08-01
  • 2015-03-03T07:47CST
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_270-018, PRD, sort_recentQuestionsFirst
Customer projects that include: Goldwood GT-25 4" Cone Tweeter
