270-082_ALT_0
Goldwood GT-1188 Piezo Horn Driver 1-3/8"-18 TPI
Brand:|Model: GT-1188|Part # 270-082
Goldwood's GT-1188 high power piezo driver is an excellent replacement for the popular Motorola/CTS KSN1188A. With an internal protection circuit, this driver can handle up to 200 watts RMS.
$9.78
Buy 10-49 $9.00
Buy 50+$7.94
Part # 270-082
  • Makes an excellent low priced upper midrange/tweeter driver
  • 1-3/8" 18 TPI mount for easy connection to many popular horns
  • Piezo drivers do not require a crossover and are an easy load for most amps
  • Extremely fast transient response
Built in transformer circuit for increased output and power handling. Similar to KSN1188A.
Specifications: • Power handling: 200 watts RMS • Frequency response: 800 to 30,000 Hz • SPL: 93 dB 1W/1m • Mounts to any 1-3/8"-18 TPI horn • Dimensions: Overall diameter: 4", Depth: 2-1/2".
  • Mounting Type1-3/8"-18 TPI
  • Exit Diameter1"
  • Diaphragm MaterialPiezo Ceramic
  • Power Handling (RMS)200 Watts
  • BrandGoldwood
  • ModelGT-1188
  • Part Number270-082
  • UPC844632040979
  • Product CategoryHorn Drivers
    (12 Reviews)
  • Weight0.7568 lbs.
View similar products to the Goldwood GT-1188 Piezo Horn Driver 1-3/8"-18 TPI
in the Horn Drivers product category.
Goldwood GT-1188 Piezo Horn Driver 1-3/8"-18 TPI is rated 3.8333 out of 5 by 12.
Rated 5 out of 5 by from Great sounding horn driver at a great price!I've used these in rebuilding PA cabinets. They sound very good, handle the power and are very affordable.
Date published: 2014-01-27
Rated 5 out of 5 by from Piezo replacementI used this to replace the kustom 15 piezo and everything sounds clearer and brighter. Power rated at 60 watts - i cranked them up and no troubles with a 200 watt powered mixer. Worth it pick them up.
Date published: 2013-03-14
Rated 3 out of 5 by from Good back up driverThis is a driver that is a good back up for a low level or entry level monitor horn. It does have a reasonable quality and I would not hesitate to use it again.
Date published: 2010-11-15
Rated 2 out of 5 by from Emergency replacement tweetsI'm a sound guy here in Chi-town for several bands, I bought these for emergency purposes. In case I blow out a horn during a gig. I have several JBL SR & MR series cabs. At $120.+ for diaphragms, I can't afford to keep back-ups on hand. So, I have a pair of these to switch out at a moments notice. I know, their piezos. But in this economy, try having 2 or 3 JBL spares lying around. I have yet to use them, but I know I won't be disappointed or embarrased at a gig. In the meantime, I then order the JBL.
Date published: 2010-11-02
Rated 1 out of 5 by from Big nothing.If you put enough power into it, you can get a high pitch screech and some radio stations. Otherwise it puts out about as much sounds as a pair of earphones. I found a better 2 inch tweeter at a local pawn shop for $0.99 and went with that instead.
Date published: 2009-10-25
Rated 4 out of 5 by from A very loud Piezo - waddya want?...This tweeter driver does exactly what it shyould - it plays very loud. It is far better than a typical piezo, but remember, it IS still a piezo! These usually sound extremely harsh due to people running them with no crtossover, and attaching them to a large throat horn. Here's my secret - even though it is technically a "plug & play " (no crossover needed) driver, USE A "REAL" CROSSOVER WITH IT! I'm using a 12Db /oct at 1800Hz. It is attenuated down -3db relative to the woofer, and is running 180 Degrees out of phase relative to the woofer (Woofer is an Eminence 15" PA speaker). Remember, this isn't a high dollar titanium driver - it's a piece of plastic - but overall it sounds great if you take the time to tweak it correctly.
Date published: 2009-06-15
  • 2016-02-14T06:48CST
  • co_hasreviews, tv_0, tr_12
  • loc_en_US, sid_270-082, PRD, sort_mostRecent
I am repairing defective Nady pfw15 monitors. How can I test a driver to make sure its not the crossover that's bad? or vice versa.
Asked by: Blackout
Date published: 2015-09-02
  • 2016-02-13T07:44CST
  • loc_en_US, sid_270-082, PRD, sort_recentQuestionsFirst
