270-204_ALT_0
Goldwood GM-450PB 2" High Frequency Horn
Brand:| Model: GM-450PB
These large format horns are extremely durable and will withstand the rigors of any PA application.
  • Horn dimensions: 17.7" W x 9.8" H x 9.1" D
  • Large format horn for 2" drivers
  • 90° H x 40° V dispersion
  • Heavy-duty reinforced ABS construction
  • Useable to 500 Hz
270-204
Weight: 5 lbs.
IN STOCK
List Price$69.95
You Save30%
$49.25
Buy 4-up$45.31
Part # 270-204
These large format horns are extremely durable and will withstand the rigors of any PA application. Excellent pattern control and directivity down to the lower frequency limit of 500 Hz. The 3/8" thick ABS construction with reinforcing ribs supports the heaviest of 2" exit compression drivers with ease.
Specifications: • Throat diameter: 2" • Bolt pattern: four holes on 4" diameter circle • Cutoff frequency: 500 Hz • Nominal coverage: 90(degree) H x 40(degree) V • Horn dimensions: 17.7" W x 9.8" H x 9.1" D • Cutout dimensions: 15-3/4" W x 8" H.
  • Mounting Type4-Bolt
  • Entry / Throat Diameter2"
  • ConstructionABS
  • BrandGoldwood
  • ModelGM-450PB
  • Part Number270-204
  • UPC643420710045
  • Product CategoryHorns & Waveguides
    (9 Reviews)
  • Weight5 lbs.
View similar products to the Goldwood GM-450PB 2" High Frequency Horn
in the Horns & Waveguides product category.
Goldwood GM-450PB 2" High Frequency Horn is rated 5.0 out of 5 by 9.
Rated 5 out of 5 by from Great features killer price!This one is a winner! It solid, thick 3/8" reinforced plastic. Its strong enough to hold the Selenium D408ti driver its bolted to. And really made a difference in sound compared to the older horns my builder got. Night and day difference would recommend!!
Date published: 2014-07-20
Rated 5 out of 5 by from Can't TOUCH this!A genuine JBL replica! American ingenuity meets Chinese industry! A match made in heaven.These CD lenses exceeded my expectations and prior experiences with similar products. We're talking:Build QualityEngineering Quality (Sound Quality)Purchased a couple for the new dorm-room build. They sport a fairly serious 3/8" ABS construction, with thick spines that provide additional strength across the backs of each major panel. So, all-in-all, no worries about strength, resonances, durability, etc. Nice things to cross off the list, particularly for such an inexpensive horn.But how do they Sound?In a word, good. About as good as any spin on Don Keele's creation can sound. These represent an appreciable effort to improve the listenability of CD horns over the 80s' machines without sacrificing much of their lower-frequency loading benefits.First off, the designers eliminated all sharp edges within the horn, save for those at the end of the slot, to reduce some of the diffraction nasties associated with this CD format. Towards similar ends, the engineers also slanted the top and bottom sides of the diffraction slot and bored a slight, circular cut into the length of the left and right sides of the slot to cut down on the development of standing waves. Good work!Listening (with a dose of eq to lift the sagging VHF response and dipping lower midrange, starting around 800Hz or so) indicated (to my ears, anyhow) that these lenses offer a reasonable sound quality advantage over their ancestors.That said, I don't foresee Earl Gedees (or any dedicated member of the EconoWave crowd) running out to buy a pair. No number of small enhancements eliminates the relatively severe time-domain distortions inherent to the application of a diffraction slot to achieve high VHF dispersion.On-axis listening (after parametric EQ boost to compensate for dropping power response) proved extremely uncomfortable, with a brash, squeaky sound in spite of a level frequency response. Slightly (15 degrees) off-axis listening, however, offered nearly the same, level frequency response with far, far less of the same harshness. Passable. I would appreciate any insight on this effect.I also plan to experiment with stuffing the slot and the transition region from the slot to the expansive region of the lens with a variety of foams. From what I've read and what I've worked out on paper during lunch breaks at work, this approach may have something to offer.
Date published: 2012-08-18
Rated 5 out of 5 by from GREAT LENS!I've had 4 of these for over six years. I originally bought them because I was replacing 1" exit drivers and lenses with 2" exit drivers and this lens allowed me to do so with a minimum of modification to the speaker cabinet. I originally went with dimensions over performance when choosing these, but I've never been disappointed in these lenses. They've seen several cabinets and drivers. I recently pulled them from a set of cabinets and am planning to build a new set of cabinets around these lenses. I was nervous about plastic too, but these are tough and still look new after a little dusting.I've loaded them with JBL 2446 Drivers and the old (long discontinued) Eminence PSD3003. They have sounded great with both!
Date published: 2011-06-08
Rated 5 out of 5 by from Best kept secret for 2" horns.I bought these because of the price and they have the specs I wanted. However, I was concerned about the manufacturer and the light weight plastic. When I mounted my EV DH1s to these I could here an immediate improvement with the openess, high frequency extension and, clarity. These are a steal at $50.00 each.I highly recommend these horns for your 2" drivers.
Date published: 2009-12-19
Rated 5 out of 5 by from loved itloved it so i bought more...
Date published: 2008-07-23
Rated 5 out of 5 by from great horn for the moneyI was worried about buying a no name horn lens but this one is a winner! It solid, thick 3/8" reinforced plastic. Its strong enuff to hold the Selenium D405ti driver(#264-218) its bolted to. Sounds Great
Date published: 2008-07-08
  • 2015-03-28T06:22CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_270-204, PRD, sort_mostRecent
new at this, .Is this a complete horn with driver?
Asked by: eglide
Would this horn fit a Yamaha S115V?
Asked by: MarioHermes
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-03-19
Does this horn come with bracket?
Asked by: masahide1014
This horn lens is intended for cabinet mounting and does not require a bracket.
Answered by: Chrisf
Date published: 2013-09-08
  • 2015-03-28T06:23CST
  • loc_en_US, sid_270-204, PRD, sort_recentQuestionsFirst
Customer projects that include: Goldwood GM-450PB 2" High Frequency Horn
