Goldwood 3" x 7" Wide Dispersion Piezo Horn Mid/Tweeter
Brand:|Model: GT-1025|Part # 280-062
• Similar to KSN1025 • Power handling: 60 watts RMS/75 watts max • Frequency response: 1,800-30,000 Hz • SPL: 90 dB • Manufacturer model number: GT-1025 • Dimensions: Height: 7-1/4", Width: 3-1/10", Depth: 4".
$2.90
Buy 10-49 $2.48
Buy 50+$2.25
Part # 280-062
Specifications: • Similar to KSN1025 • Power handling: 60 watts RMS/75 watts max • Frequency response: 1,800-30,000 Hz • SPL: 90 dB • Manufacturer model number: GT-1025 • Dimensions: Height: 7-1/4", Width: 3-1/10", Depth: 4".
  • Diaphragm MaterialPiezo Ceramic
  • Power Handling (RMS)60 Watts
  • BrandGoldwood
  • ModelGT-1025
  • Part Number280-062
  • UPC643420500240
  • Product CategoryHorn Loaded Bullet Tweeters
    (39 Reviews)
  • Weight0.2 lbs.
View similar products to the Goldwood 3" x 7" Wide Dispersion Piezo Horn Mid/Tweeter
in the Horn Loaded Bullet Tweeters product category.
Goldwood 3" x 7" Wide Dispersion Piezo Horn Mid/Tweeter is rated 4.2821 out of 5 by 39.
Rated 5 out of 5 by from super performance/price ratioUsing this piezo horn as a super tweeter on a discontinued 3- way BIC kevlar center channel. Crossed over with a 1.2mfd cap and padded with a Dayton 2.7ohm 10 watt resistor. Adds sizzle and ambience to any source. .excellent product.
Date published: 2014-10-21
Rated 3 out of 5 by from long range but pinched and hollow soundGreat product for the money but they sounded a little pinched and hallow sounding. they have a great long range sound potential. Would be a great tweeter for a low budget pa system
Date published: 2014-08-05
Rated 5 out of 5 by from Great source for this Piezo HornWe have used this product in our amp line for 15 years+. Now we have a great new source and we don't have to buy them by the case. The performance is the same as before. Good old Goldwod quality.
Date published: 2014-06-26
Rated 5 out of 5 by from everything goodjust what we needed.lkhsdflhpoihwefoinlsakndflknisahfoih
Date published: 2014-05-29
Rated 4 out of 5 by from nice soundI used these to replicate a larger set of speakers to match some I had for a small PA system they sound great
Date published: 2014-05-27
Rated 4 out of 5 by from using in guitar ampI took a small guitar amp made a new case w/12 " speaker & this horn tweeter it works good for this app. I use the amp for both bass & guitar practice
Date published: 2014-05-14
  • 2016-02-13T06:44CST
  • co_hasreviews, tv_0, tr_39
  • loc_en_US, sid_280-062, PRD, sort_mostRecent
is this gold wood good to use as  a tweeter or a mid bc im looking for a tweeter n not sure if this will work thanks
Asked by: speakerfreak68
Yes this will work fine as a tweeter.
Date published: 2015-03-17
im looking to replace an existing horn tweeter. the hole i have is  4 3/4" x 2 3/8". overall original tweeter size is 6" wide x 3 1/2" tall. just wondering if this item will fit in that hole or not (i know original screw holes will not line up ofc)
Asked by: pantstain
Unfortunately no, this requires a hole that is 6"W x 2-1/8"H. We do not have a horn tweeter that will fit directly in that hole, this would be the best option if you could enlarge the opening you have.
Date published: 2015-02-21
How are these measured? Outside measurements, or size of hole needed to mount?
Asked by: Pahako
The dimensions provided for this horn are exterior/overall dimensions.
Date published: 2014-11-17
What is the best way to lower the volume in relation to the woofer?
What is the best way to lower the volume of this tweeter if it is too loud compared to the woofer. I like piezo tweeters, so I would really like to know.
Asked by: Drumolator
You will have to wire an 8 ohm resistor in parallel with the tweeter and install a variable L-pad in order to bring the volume level down.
Do I need to use a crossover with this horn. I have 2 8 ohm full range 3" Tang Band's hooked together with the horn in parallel to DTA-1
They sound great! Horn made a big difference. 4 by 4 by 16 enclosure
Asked by: rob1803
Piezo tweeters do not require crossovers.
I need a horn this size for a custom application, mainly because of it's depth. does anyone know if the driver is a screw on, or removeable at all?
Asked by: db dave
This driver is not removable. it is a one piece design.
Answered by: Chrisf
Date published: 2013-05-18
  • 2016-02-13T07:39CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_280-062, PRD, sort_recentQuestionsFirst
