Gold Spade 8 AWG 1/4" 2 Pair
Gold Spade Lug Crimp Terminal 8 AWG 1/4" 2 Pair
High quality, gold plated solderless ring terminals and spade connectors for high power, high current AC/DC connections.
095-668
Weight: 0.04 lbs.
IN STOCK
$2.86
Buy 10-up$2.50
Part # 095-668
Qty:  PK
High quality, gold plated solderless ring and spade terminals for high power, high current AC/DC connections. Perfect for automotive, RV and marine applications. 2 pair (red/black) per package.
  • Connector TypeSpade / Fork
  • Wire Gauge8 AWG
  • Terminal / Stud Size1/4" (0.250")
  • BrandParts Express
  • Part Number095-668
  • UPC844632018701
  • Product CategorySolderless / Crimp Terminals
  • Unit of MeasurePK
    (8 Reviews)
  • Weight0.04 lbs.
View similar products to the Gold Spade Lug Crimp Terminal 8 AWG 1/4" 2 Pair
in the Solderless / Crimp Terminals product category.
Gold Spade Lug Crimp Terminal 8 AWG 1/4" 2 Pair is rated 4.375 out of 5 by 8.
Rated 5 out of 5 by from Gold Spade 8 AWGI got two sets of these thinking I could also use them on the amp side...boy was I wrong. They're too big for the amp side, but work fine for the ground. I got some rings for the positive at the local autozone. The other minor problem I had was crimping these puppies. You need a bigger crimper or a vise which is what I also ended up using to make sure I got them nice and solid. I have a smaller crimper which didn't help much on these for me. This is why I mentioned on my other review that a smaller 10 awg wire may work better on smaller setups with one amp and a set of speakers or two. It should also cost a bit less going smaller and connectors may be easier to find for the 10 vs the 8 awg wire.
Date published: 2014-09-14
Rated 4 out of 5 by from Good connection, not so good shieldI crimped these down hard and they took it. Solid connections on the crimp. Only negative is that I crimped these on wire that has a thick shield and the rubber shield that slides over the crimp doesn't actually fit over the wire I bought. So I ended up using heat shrink to shield the termination. Good product though!
Date published: 2014-04-13
Rated 5 out of 5 by from Quality productGreat for 8 gauge wire heavy duty
Date published: 2009-07-29
Rated 5 out of 5 by from Nice Quality 1/4 inch spade lugsHigh quality 1/4 inch spade lugs. Well made and great for connecting high end audio speakers etc.
Date published: 2009-01-23
Rated 3 out of 5 by from Could be sized better for audiophile use...This is the only inexpensive audio-quality 1/4" spade Parts Express offers. Unfortunately the 1/4"-size spade only comes with an 8-gauge wire ferrule, and this size is too large to secure the 14-gauge or 12-gauge wire used by most people, even with a dedicated high-end terminal crimper (tends to flatten out rather than secure the smaller gauge wire). If you do use 8-gauge wire, bewarned that most terminal ratchet crimpers out there only handle up to 10 gauge - you'll need a larger, heavier-duty crimp tool to handle it.
Date published: 2008-06-29
Rated 4 out of 5 by from Not rough enough, but for that money...Hard to find better for that price. Not rough enough (one was broken during crimping), but overall-- good. Thick coating, easy to use. Do not forget fine crimping tools :)
Date published: 2008-05-18
could i use these on my 12AWG speaker cable  attached to 5 x 200 watt amp?
Asked by: socbutter
These are intended for use on 8 awg wire. 12 gauge will not fit and crimp properly.
Answered by: Chrisf
Date published: 2014-06-03
Customer projects that include: Gold Spade Lug Crimp Terminal 8 AWG 1/4" 2 Pair
