Gold Recessed 5-Way Banana Speaker Terminal Rectangle
Gold Recessed 5-Way Banana Speaker Terminal Cup Rectangle
Rectangular recessed panel with gold plated posts and knurled knobs. Color coded. Accepts up to 8 gauge wire. Can also be used with dual banana plugs. Overall size: 3-5/8" by 3-1/8"; cutout: 2-7/8" x 2-1/8". Includes gasket.
260-309
Weight: 0.1848 lbs.
IN STOCK
List Price$7.49
You Save26%
$5.50
Buy 10-49 $4.94
Buy 50-up$4.25
Part # 260-309
Dimensions: • Overall size: 3-5/8" by 3-1/8"; cutout: 2-7/8" x 2-1/8" • Includes gasket.
  • BrandParts Express
  • Part Number260-309
  • UPC844632017575
  • Product CategoryTerminal Plates & Cups
    (41 Reviews)
  • Weight0.1848 lbs.
View similar products to the Gold Recessed 5-Way Banana Speaker Terminal Cup Rectangle
in the Terminal Plates & Cups product category.
Gold Recessed 5-Way Banana Speaker Terminal Cup Rectangle is rated 4.5122 out of 5 by 41.
Rated 5 out of 5 by from speaker binding postsNice quality for the money. Was easy to work with. I would buy again. The posts are five-way however I am using with banana plugs. The hole in the post can take very thick wire, my guess at least 8 gauge.
Date published: 2014-01-26
Rated 5 out of 5 by from Well built and good valueThese cups are heavier than others I've used over the years. Well built, easy to install and good value.Just wish black screws would have been included. (If they were, would have given 5 stars in all categories.
Date published: 2013-03-08
Rated 5 out of 5 by from Good TerminalYou can solder with out melting plastic, comes with gasket preinstalled, making installation a breeze. Our favorite terminal.
Date published: 2012-08-13
Rated 5 out of 5 by from Good ProductSolid, look nice. Was able to solder to them without the plastic melting. Very happy.
Date published: 2012-06-16
Rated 5 out of 5 by from Great terminalsThese are high quality and affordable terminals. I would recommend them to anyone.
Date published: 2012-04-18
Rated 5 out of 5 by from great terminal at a good price, been using them for yrs.I have been using these terminals for years and will continue to use them for years to come, I just wish they were >$5 but that is the price we currently have to payI highly suggest using the #6 3/4" screws, part# 081-435 to give a professional look to the terminals as well as speakers small enough to not require hurricane nutsEven though they are self sealing I always add some speaker caulk around the inside of the terminal base especially when used on sealed enclosures...its cheap, easy and quick to do for the insurance/piece of mind it providesif you want a professional look you can always counter sink the terminals by adding a scape piece of 1/2" MDF behind the area ther terminal will be installed, that way the baffle will not be a weak point, the final product is worth the extra work, especially if your building the speakers for a customer
Date published: 2012-11-20
What are the screw hole measurements for this terminal plate?
I am looking to replace my current speaker terminal plates which have broken, but mine measure out slightly differently than everything else I have been able to find.The plates which need replacing have an overall size (edge to edge) of 3 7/8" by 3 1/4" and cutout size of 3" by 2 3/8".As you can see, all these are only eighths of an inch off from your items, which is why I would like to confirm the size, based on screw hole if possible, to determine whether there is compatibility.Thanks!
Asked by: Joseph D.
Well Joseph, you are in luck. The PE item you are looking at, uses a cutout slightly larger than the one you are replacing. So, if you can't find the exact replacement---I suggest this item. A larger cutout does require a larger hole though--if the box is particle board, use a fine tooth saw and use the new plate as the "template". Exact replacements can be hard to fine--but this item is gold plated so the terminals should last years.
Answered by: Joe from San Francisco
Date published: 2013-08-22
Customer projects that include: Gold Recessed 5-Way Banana Speaker Terminal Cup Rectangle
