Gold RCA Super Plug Connector Red 8.3 mm Cable Entry
Brand:|Part # 091-055
RCA super plugs are a great way to add some pizzazz to your next RCA cables.
$2.58
Buy 10-99 $2.40
Buy 100+$2.17
Part # 091-055
  • Attractive machined shell
  • Wide 8.3 mm cable entry allows use with large-diameter cables or Techflex
  • Gold-plated contacts for pure signal transmission
The precision-machined shell of these RCA super plugs is cosmetically impressive and gold-plated contacts ensure quality performance. With the 8.3mm cable entry, it's easy to craft RCA interconnects using large wire or even Techflex.
Specifications: • Contact plating: gold • Sold per: each • Finish: red • Termination style: solder • Entry hole: 8.3 mm • Dimensions: 0.5" x 1.88"
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • BrandParts Express
  • Part Number091-055
  • UPC844632010996
  • Product CategoryRCA Connectors
    (2 Reviews)
  • Weight0.0396 lbs.
View similar products to the Gold RCA Super Plug Connector Red 8.3 mm Cable Entry
in the RCA Connectors product category.
Gold RCA Super Plug Connector Red 8.3 mm Cable Entry is rated 4.0 out of 5 by 2.
Rated 4 out of 5 by from Maybe the best value RCA plugs Parts Epress offersI just finished a couple of custom RCA cables. I wanted a custom length, something that looks awesome and a fun project. I wanted the Dayton locking RCA but after reading the Theater Shack.com tutorial I knew I would be happy with these and the ease of installation, the looks and the performance. Everyone looking to make their own RCA interconnects should read this.I used these and the Belden 8412 mic cable and neon blue 1/4" Techflex cable. The 8.3 mm opening fits the cable with Techflex like a glove. The set screw securly locks both in place, no need for complicated shirk wrap. Warning, do not heat the RCA center cup too long. The insulation will soften and move the pin off center. It happened to me twice. Reheat the pin and move it back to center.The ground connections allow a custom fit. OK, the ground connections are sloppy and you have to crimp them a bit to get a snug fit on the female RCA. I am running this on an budget 2.1 audiophile system. An iPod feeds a Fiio preamp e09K. The line out runs to a Dayton SA1000 sub amp to a 15" Ultimax sub in a custom sealed box. The preout feeds a digital Topping TP60 amp which goes to the amazing HSU Research HB-1 MKII bookshelf speakers full range.Overall this was a fun project and the performance and cosmetics were exactly what I was looking for.
Date published: 2014-06-29
Rated 4 out of 5 by from Red RCA PlugNot bad units for the price. Don't know why they are more than the black and yellow ones, (have used all three), but they are easy enough to work with.Large frame, easy enough to solder . Room enough for two ground wires if one so desires.Easy enough to take apart also.Large outside barrel, looks nice enough.Have used many .
Date published: 2012-02-22
  • 2016-02-12T06:49CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_091-055, PRD, sort_mostRecent
