091-050_ALT_0
091-050_ALT_1
Gold RCA Super Plug Connector Black 8.3 mm Cable Entry
RCA super plugs are a great way to add some pizzazz to your next RCA cables.
  • Attractive machined shell
  • Wide 8.3 mm cable entry allows use with large-diameter cables or Techflex
  • Gold-plated contacts for pure signal transmission
091-050
Weight: 0.0396 lbs.
IN STOCK
$2.58
Buy 10-99 $2.40
Buy 100-up$2.17
Part # 091-050
The precision-machined shell of these RCA super plugs is cosmetically impressive and gold-plated contacts ensure quality performance. With the 8.3mm cable entry, it's easy to craft RCA interconnects using large wire or even Techflex.
Specifications: • Contact plating: gold • Sold per: each • Finish: black • Termination style: solder • Entry hole: 8.3 mm • Dimensions: 0.5" x 1.88"
  • GenderMale / Plug
  • Mounting TypeCable Mount
  • BrandParts Express
  • Part Number091-050
  • UPC844632010989
  • Product CategoryRCA Connectors
    (3 Reviews)
  • Weight0.0396 lbs.
View similar products to the Gold RCA Super Plug Connector Black 8.3 mm Cable Entry
in the RCA Connectors product category.
Gold RCA Super Plug Connector Black 8.3 mm Cable Entry is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Worked well with my cable.I needed some connectors to use with some Blue Jeans LC-1 cable, these fit the bill perfectly. Nice design, and solid construction.
Date published: 2012-11-15
Rated 5 out of 5 by from Good for large cableI used these on some leftover 8.3mm Monster Cable and they worked well and look good. The best feature is the inner frame design, which is sturdy and makes it easy to terminate both the shield and neutral on one end. Only thing negative is that a little too much heat on the center pin can melt the plastic and make it go off-center.
Date published: 2009-10-28
Rated 5 out of 5 by from you can beat price/value ratio for these plugsLarge opening for the cable, very attractive styling and overall quality make this productvery arrtactive
Date published: 2009-07-02
Customer projects that include: Gold RCA Super Plug Connector Black 8.3 mm Cable Entry
