091-1200_ALT_0
Gold RCA Female To F Female with Nut Hex Type
Brand:|Part # 091-1200
The "Installer Friendly" wall plate system gives you the flexibility to quickly custom build your wall plates on the job site. For using F cables to connect behind RCA Female for better connections.
List Price$2.99
You Save34%
$1.98
Buy 10-49 $1.86
Buy 50+$1.47
Part # 091-1200
Gold-plated connectors.
  • BrandParts Express
  • Part Number091-1200
  • UPC844632017988
  • Product CategoryWall Plate Hex Connectors & Adapters
    (9 Reviews)
  • Weight0.0375 lbs.
Gold RCA Female To F Female with Nut Hex Type is rated 4.2222 out of 5 by 9.
Rated 4 out of 5 by from Must have gotten a bad batchMine must have come out of a bad batch. I couldn't push the F cable connector in enough to start turning the screws because something on the inside was blocking the center conductor. This is fixable; I just took a very small drill bit and a hammer, then banged on it to loosen up the innards a bit. Worked fine after that.
Date published: 2010-12-06
Rated 5 out of 5 by from Great productGreat, normally hard to find product. I have used these on about 5-6 different projects and they work great.
Date published: 2010-05-21
Rated 5 out of 5 by from Great ProductGreat fit/finish. Used it to run my subwoofer output over RG6 already in the wall. Works great.
Date published: 2010-02-21
Rated 4 out of 5 by from Hard to find part elsewhereThis is the part I needed and many local stores didn't carry it. Even Radioshack! I use this connector for an in wall application going from my subwoofer, direct connet to a wall plate with RG6 Co axial cable routing back to my receiver.... part works great and cheap price!!
Date published: 2010-01-27
Rated 4 out of 5 by from Good QualityWell made Works good
Date published: 2009-03-28
Rated 3 out of 5 by from Not the same as pictureThe ones I received are not like the one in the picture. The nut is thicker which doesn t leave enough threads to fully thread an F connector. The one in the picture is gold and purple. The ones I received are gold and white. They will still work but do not deserve a high rating.
Date published: 2008-10-10
  • 2016-02-05T06:44CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_091-1200, PRD, sort_mostRecent
