Gold Plated Banana 5-Way Speaker Terminal
Gold Plated Banana 5-Way Speaker Wire Binding Post Terminal
Rectangular terminal with gold plated binding posts. Includes gasket for a leak free seal. Color coded. Accepts up to 10-12 gauge wire. Also can be used with dual banana plugs. Dimensions: 2-1/8" W x 15/16" H.
260-302
Weight: 0.066 lbs.
IN STOCK
$2.88
Buy 10-49 $2.60
Buy 50-499 $2.25
Buy 500-up$1.98
Part # 260-302
Rectangular terminal with gold plated binding posts. Includes gasket for a leak free seal. Color coded. Accepts up to 10-12 gauge wire. Also can be used with dual banana plugs. .
Dimensions: • Outside Dimensions: 2-1/8" W x 15/16" H • Cutout required 1-3/8" H x 3/4" W.
  • BrandParts Express
  • Part Number260-302
  • UPC844632017568
  • Product CategoryTerminal Plates & Cups
    (20 Reviews)
  • Weight0.066 lbs.
View similar products to the Gold Plated Banana 5-Way Speaker Wire Binding Post Terminal
in the Terminal Plates & Cups product category.
Gold Plated Banana 5-Way Speaker Wire Binding Post Terminal is rated 4.55 out of 5 by 20.
Rated 5 out of 5 by from Great Binding PostInstalled 2 of these on my Bose 101 speakers. The original spring clips broke after 25 years, The new Banana binding post worked perfectly, Only took 5 minutes to install. So glad I went for the Banana type binding post and not the oem spring clip. Don't understand why Bose would not use this type to begin with, there speakers are not cheep. As a side note I called Bose and they wanted $75.00 to replace one speaker with new OEM type spring clip, + shipping. Not complaining about Bose, Just thought that $75.00 was a lot of $ for one new spring clip. And Its something anyone can do with a soldering iron.
Date published: 2014-04-14
Rated 5 out of 5 by from Great for Small Subwoofer Enclosures-Car InstallsI love the size of these terminal posts for small sub enclosures that I'm presently constructing for my car. For 6 3/4" subs, I could not see cutting out a huge hole for the larger cup type terminal posts. These require a very small cutout to mount and work perfectly and are gold plated for great signal transfer.
Date published: 2014-04-13
Rated 5 out of 5 by from Excellent ProductThis binding post is perfect for speaker restoration where a large hole for a cup is not preferred.
Date published: 2014-02-03
Rated 5 out of 5 by from A serfs view!Works as advertised. Substantially made. signal degradation is minimal. good value for the monopoly paper!! A Serferdude
Date published: 2013-09-17
Rated 5 out of 5 by from good value - good quality for the priceAn excellent choice for replacement of those dinky "clip" terminals that are found on so many speakers. Mounting width is the same as those (2 1/8") too, so exchange is easy.Also an excellent choice for DIY projects too.
Date published: 2013-08-19
Rated 4 out of 5 by from SolidGood value for the price. Exactly as advertised; gold plated connections.
Date published: 2012-11-06
Can I swap out the binding posts for RCA jacks?
Looking to replace the binding posts with RCA-CHRBjacks. Is this possible?
Asked by: Nino
Can you swap in RCA jacks? Of course you can.Is the product intended to allow you to do so easily? Of course not.Will it work well? There is only one way to find out.If you just want a small plate upon which to mount your RCA jacks I would suggest that you fabricate something out of some scrap plastic or hard board. That way if it doesn't work out the way you want you can cut off another chunk and try again. These cost $3.50 a pop, and leave you little room for error. Plus, fabricating your own can be a true DIY endeavor, and with effort it will result in something nice looking and functional. Using this is most likely going to result in some half functional Franken-terminals.
Answered by: Travis Rysdam
Date published: 2012-06-13
What is the hole diameter or screw size?
I would like to know what screws to order with the terminal plate. Thank you.
Asked by: RickH
The wire holes handle up to #10 guage stranded wire and the banana plugs are standard banana plug sized split for ring tightening.. I don't think anyone has ever measured them.
Answered by: Nitnub
Date published: 2013-10-19
What is the center-to-center distance of the two small mounting holes on the mounting plate?
Asked by: b17flyer
The distance between screw holes is 1-3/4" center to center.
Date published: 2013-06-15
What are the connection options opposite the bananas-those which would reside within the body of the cabinet?
Asked by: Jeanluc
The opposite side uses .205" terminals to either solder to, or connect with female solderless terminals.
Date published: 2014-01-07
What do you mean by 5-Way Speaker Wire Binding Post Term.... My spring clips broke on my Bose 101 and need replacement.. will these work, seem to be same size.thanks Francis
Asked by: MrFrancis49
A 5 way binding post is a generic term and means these can usually accept 5 different types of wire connections: Bare wire, banana plugs, pin connectors, spades and ring terminals. These will work for replacing a spring loaded terminal without a problem, the dimensions are listed on the site.
Date published: 2014-04-07
Customer projects that include: Gold Plated Banana 5-Way Speaker Wire Binding Post Terminal
