091-340_ALT_0
Gold Binding Post Banana Jack Pair Extra Long Shaft w/ Solder Tabs
Perfect for high power, high quality speaker cabinets. Quality gold plated binding posts with side entry wire/pin clamp that accepts up to 8 gauge wire. Extra long rear bolt (1-1/4") with knurled shaft for mounting in thick wood cabinets. Sold in color coded pairs with terminals.
091-340
Weight: 0.09 lbs.
IN STOCK
List Price$12.99
You Save26%
$9.49
Buy 10-99 $8.25
Buy 100-up$7.25
Part # 091-340
Qty:  PR
Perfect for high power, high quality speaker cabinets. Quality gold plated banana jack binding posts with side entry wire/pin clamp that accepts up to 8 gauge wire. Extra long rear bolt (1-1/4") with knurled shaft for mounting in thick wood cabinets. Sold in color coded pairs with solder terminals that can also accept 1/4" female disconnects.
  • Style / TypeSingle
  • Contact PlatingGold
  • BrandParts Express
  • Part Number091-340
  • UPC844632017285
  • Product CategoryBinding Posts & Plates
  • Unit of MeasurePR
    (6 Reviews)
  • Weight0.09 lbs.
View similar products to the Gold Binding Post Banana Jack Pair Extra Long Shaft w/ Solder Tabs
in the Binding Posts & Plates product category.
Gold Binding Post Banana Jack Pair Extra Long Shaft w/ Solder Tabs is rated 4.0 out of 5 by 6.
Rated 4 out of 5 by from Very Nice But Will Not Work For MeThese look like real quality posts...unfortunately I did not do my homework and they will not fit my homebuilt enclosures (one inch high density fiberboard). My fault and not sure they are worth returning.
Date published: 2014-10-02
Rated 5 out of 5 by from Banana plugs work best - nice tight connectionI purchased these to replace the cheap plastic 90's binding posts on a pair of Apogee Acoustics Centaur Major speakers. The posts are a perfect replacement, the rear bolt is the same diameter and plenty long enough.I did have to get some faucet aerator washers to insulate the back side. The old binding posts would not come out of the front mounting bracket, even with a hammer, so the rear bracket became the front and the washers became the rear bracket, since you can't see it anyway. The plugs still rotate if you try hard enough, the stock binding plugs were glued in or something to keep them from rotating.As another reviewer mentioned, these are less than ideal for bare wire or spades. I have some beefy Nakamichi spades that don't work well with these at all, but were fine with the BPA-38G's. I couldn't use the BPA's because the rear bolt was too thick, but I wound up getting some Sewell Silverback banana plugs and the connection is VERY secure.This whole binding post adventure started because I was trying to position my speakers in the room and my old banana plugs kept falling out of the binding posts. The spades sort of solved that, except they were too thick to fit in the stock binding posts. The BPA binding posts were too thick to fit in my speakers, and these BPT's fit perfectly, but don't work well with spades. The Sewell banana plugs combined with these binding posts seems perfect, easy to connect/disconnect, looks nice, and very secure even with heavy jacketed 4 strands of 10-gauge wire hanging off the back of them.More than you wanted to know? Probably.
Date published: 2012-01-31
Rated 1 out of 5 by from Bad bare wire side entry design!Side entry holes are well chamfered, but center pocket is so deep that when screwing down to tighten, it will tend to shear the wire on sharp edge of chamfered side entry hole. They appear OK for use with banana plugs but for spades or bare wire thay leave a lot to be desired. I took the loss in purchasing these (based on past reviews), and I'm now ordering the BPA-38Gs which look much better in regard to my complaint.
Date published: 2008-08-25
Rated 4 out of 5 by from High Quality for the PriceI did not actually use these binding posts since they turned out to be too long to fit my speakers due to the placement of internal bracing in my speakers. My fault. I did use the metal lock washers, however. These posts, if not to long for your application, seem to be very high in quality and very flexible in terms of the types of terminations you can use inside and outside the speaker. The posts need #10 O-rings/lugs to fit around them. The outside will accommodate very large-gauge bare wire and the edges of the hole through the post are nicely rounded so as not to shear off fine wire strands if you use bare wire connections as I like to do.
Date published: 2008-05-16
Rated 5 out of 5 by from Works great!Works great. Perfect fit for the PE boxes.
Date published: 2007-08-21
Rated 5 out of 5 by from Best binding posts for the money bar noneThese binding posts are the highest quality binding posts I have owned,. and I've bought some very expensive binding posts before.Highly recommended.
Date published: 2007-08-20
What is the total length? And what's the diameter of the threaded shaft?
Asked by: Bosssho
The total length of this binding post is 2", the threaded shaft diameter is 3/16".
Date published: 2014-09-11
What is the threaded shaft diameter?
Asked by: SIRR
The threaded shaft diameter is .185".
Date published: 2014-04-28
Hi, Do you have any dimensional information for this Item # 091-340. Specifically the diameter of the knurled end and mounting base....or what ever is the larger of these two dimensions.
Asked by: Dynacoguy
this is 11mm or 0.432 inches. at the knurled part. The barrel is the same diameter
Answered by: Chrisf
Date published: 2014-04-11
Customer projects that include: Gold Binding Post Banana Jack Pair Extra Long Shaft w/ Solder Tabs
