Galaxy Audio S5N-16 5" Neodymium Full Range Driver 16 Ohm
Brand:|Model: S5N-16|Part # 290-018
Galaxy Audio introduces the 5" driver of the future! Like its predecessor, this speaker is tailored to reproduce a frequency range from 150 to 18,000 Hz.
Comparable Items In Stock:
Part # 290-018
  • Neodymium magnet structure
  • Same performance, 1/3 the weight!
  • Cast aluminum frame
  • Front or rear mounting
  • Edgewound voice coil
Galaxy Audio introduces the 5" driver of the future! Like its predecessor, this speaker is tailored to reproduce a frequency range from 150 to 18,000 Hz. The magnet of the NEOLITE is manufactured from neodymium, which has an extremely intense magnetic field in comparison to its weight. The NEOLITE is as powerful as the previous 5" driver, yet weighs 1/3 as much. In addition, the driver is shielded. This allows the speaker to be placed near sensitive equipment that may be affected by a strong magnetic field, such as a TV or a computer monitor.
The Galaxy Audio S5N-8 controlled bandwidth transducer delivers maximum sound levels and unsurpassed durability under the most stringent operating conditions. It features an aluminum frame, 7.4 oz. neodymium magnet structure, Super Cool cooling technology, underhung voice coil, and linear spider. The 1" voice coil includes a polyimide former, and Ferrofluid cooling reduces distortion and power compression while increasing speaker life. The S5N-8 is optimized for use in infinite baffle/acoustic suspension type enclosures. Galaxy’s new 5" driver retains all the sound characteristics of the original driver without sacrificing sound, power, or reliability. It is a direct replacement for the old ceramic ferrite magnet speaker in terms of performance and sound signature.
The NEOLITE can handle 100 watts continuous/200 watts max! How is it possible for a speaker this size to handle power like that? A speaker is only as good as its ability to dissipate heat. The NEOLITE has a patented cooling system called SUPER COOL. SUPER COOL is based on three different methods of heat transfer.
Conduction
The speaker is cooled by Ferrofluid, which is a liquid agent in which the voice coil is immersed. This conducts heat away from the voice coil to the surrounding motor structure. The aluminum frame of the NEOLITE also helps conduct heat away from the motor.
Convection
The NEOLITE employs three venting chambers, which provide air flow caused by cone movement. Designed into the cast aluminum frame are cooling fins and vent holes. These fins and vent holes are strategically placed around the speaker to maximize airflow to help dissipate heat.
Radiation
The aluminum frame is painted black. The black paint helps to radiate heat away from the frame. The NEOLITE is truly unlike anything available today. Galaxy has maintained the same great sound in a much lighter package. If you are looking to put the NEOLITE in your own cabinet, it can be front or rear mounted in the enclosure. The NEOLITE is unmatched by any other 5" speaker!
  • Nominal Diameter5"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance16 ohms
  • Frequency Response150 to 18,000 Hz
  • Sensitivity91 dB 1W/1m
  • Voice Coil Diameter1"
  • Magnet Weight7.4 oz.
  • Resonant Frequency (Fs)140 Hz
  • Mechanical Q (Qms)0.83
  • Electromagnetic Q (Qes)0.72
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.08 ft.³
  • Cone MaterialPaper
  • Magnet MaterialNeodymium
  • Overall Outside Diameter5.25"
  • Depth2.41"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3290 Hz
  • Vented Volume0.05 ft.³
  • Vented F3161 Hz
  • BrandGalaxy Audio
  • ModelS5N-16
  • Part Number290-018
  • UPC691281016059
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Galaxy Audio S5N-16 5" Neodymium Full Range Driver 16 Ohm
