Galaxy Audio PA6S Powered Hot Spot Active Full Range Monitor
Brand:|Model: PA6S|Part # 245-265
The Galaxy Audio PA6S takes full advantage of recent improvements in speaker and amplifier technology, making it the lightest, most powerful, and best sounding compact PA system Galaxy Audio has ever ever offered!
List Price$399.99
You Save25%
$299.99
Part # 245-265
  • Two-way system—6.5" neodymium high-power woofer and 1.5" high efficiency Neolite tweeter
  • 170 watt Class D amplifier
  • 3 Inputs—Two combi XLR / 1/4" and one 3.5 mm stereo
  • New design of the PA6S includes the convenient mic stand insert on the bottom of the unit
  • Included mic stand adapter ensures a more stable and secure placement on any mic stand
  • Lighter weight than its predecessors while improving performance—only 6.4 lbs.
  • Integrated handle into the top of the enclosure
Over 30 years ago Galaxy Audio pioneered the small PA/personal monitor category with the innovative product called the HOT SPOT. Through the years we've offered groundbreaking designs in both powered and unpowered models. The all new redesigned Galaxy Audio PA6S is the newest powered model in the Hot Spot line since 1998. While the PA6S has been redesigned from the ground up, we have kept the basics. The newly designed outer shell has kept the distinctive shape of the original Hot Spot, but with a 21st Century look. The cabinet now uses two specially designed speaker components, the new 155 watt NEOLITE 6.5" woofer and our highly efficient 1.5" 60 watt tweeter.
The PA6S takes full advantage of recent improvements in speaker and amplifier technology, making it the lightest, most powerful, and best sounding compact PA system we've ever offered. New features such as the XLR pass-through on each channel allow independent control of mics without affecting the signal sent to the house PA. A –20 dB Pad switch on each XLR input ensures that even the hottest signals will be accepted without overdriving the inputs. An additional 1/8" Line input on Channel 2 will accept stereo or mono signals from sources such as tape or digital medial players as well as line level instruments.
Speaker Section: •  Woofer: One Galaxy Audio SW6.5 ferrofluid cooled 6.5" NEOLITE neodymium woofer • Tweeter: One ST1.5 fluid cooled 1.5" NEOLITE neodymium titanium dome tweeter • Nominal impedance: 4 ohms • Power handling capacity: 155 watts
Enclosure: • Enclosure materials: Fire retardant styrene • Color: Black • Dimensions: 7.75" x 11.75" x 6.75" (197 mm x 298 mm x 171 mm) • Net weight: 6.4 lbs. (2.9 kg)
Amplifier Section: • Rated power: 170 watts @ 4 ohms, 180 watts dynamic power • Equalization: Three-band center detent • Lo: ± 12 dB peak/dip at 200 Hz
Mid: ± 12 dB peak/dip at 2 kHz • Hi: ± 12 dB shelving at 10 kHz • Sensitivity (1 kHz octave band): 98 dB 1W/1m • Frequency response: 80 Hz - 18 kHz • Maximum SPL @ clip: 118 dB • Total Harmonic Distortion: <0.5% @ 4 ohms • Input connections: Two 1/4" Balanced/Unbalanced, Two XLR with 24V phantom power, one 3.5 mm stereo line-in • Output connections: Two XLR thru outputs, one 1/4" preamp output • Indicator LEDs: Power, Clip & Compressor • Power requirements: 120 VAC, 60 Hz • Safeguards: Short circuit current limiting, short circuit foldback limiting, thermal short circuit protection
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • Woofer Size6-1/2"
  • BrandGalaxy Audio
  • ModelPA6S
  • Part Number245-265
  • UPC691281000256
    (1 Reviews)
  • Weight8.4 lbs.
View similar products to the Galaxy Audio PA6S Powered Hot Spot Active Full Range Monitor
