Galaxy Audio NSPA Powered Nano Spot Full Range Monitor
Brand:|Model: NSPA|Part # 245-2420
Even smaller and lighter than its predecessors, the NSPA Nano Spot continues the proud tradition of the Hot Spot Series of personal monitors by Galaxy Audio. Designed for stage monitoring, the Nano Spot can also be used for computers, paging stations, and many other near-field monitoring applications.
List Price$199.99
You Save30%
Part # 245-2420
  • Small but mighty powered personal monitor
  • Quick and easy setup
  • Super simple operation
  • Huge, clear sound in a tiny package
Frequently Bought Together
Coming in at a mere 5" x 4.5" x 4.25", and only 1.75 pounds, the Nano Spot's tiny size belies its power and flexibility. Galaxy Audio is famous for the Hot Spot line of personal monitors, and the NSPA Nano Spot is among the latest additions to this winning line. The Nano Spot was designed for vocalists and instrumentalists who need to monitor their own performance, without all the gear and hassle associated with typical floor wedges. With XLR, 1/4" (balanced or unbalanced), and 1/8" stereo inputs, the Nano Spot can handle virtually any source you need to connect. It also has 24V phantom power, a 20 dB pad, and built-in compression, so anything from condenser microphones to cellphones is fair game. The 3" full range speaker is driven by an on-board 25 watt amplifier, and 2-band EQ is available right on the front panel, so there is no need for outboard gear. You can mount the Nano Spot directly to a mic stand, or use the included bracket as a wall, ceiling, or surface mount, allowing you to put the powerful sound virtually anywhere you need it, quickly, conveniently, and with the confidence that comes from Galaxy Audio's quality and reliability.
Specifications: • Power output: 25 watts • Frequency range: 150 - 17,000 Hz • Maximum SPL: 101.5 dB • THD: < 0.5% • Inputs: XLR (24V phantom powered); 1/4" TRS or TS; 1/8" stereo line in, summed to mono • Dimensions: 5" x 4.5" x 4.25" (127 x 114 x 108 mm) • Weight: 1.75 lbs. (0.793 kg).
  • Speaker TypeActive / Powered
  • ConfigurationStage Monitor
  • BrandGalaxy Audio
  • ModelNSPA
  • Part Number245-2420
  • UPC691281104732
  • Weight3.4000 lbs.
View similar products to the Galaxy Audio NSPA Powered Nano Spot Full Range Monitor
