245-2422_ALT_0
245-2422_ALT_1
245-2422_ALT_2
245-2422_ALT_3
245-2422_ALT_5
245-2422_ALT_6
245-2422_ALT_7
245-2422_ALT_9
Galaxy Audio MS5 Micro Spot Full Range Monitor with Volume Control
Brand:|Model: MS5|Part # 245-2422
Galaxy Audio is proud to present the MS5 Micro Spot 5 personal monitor, updated and upgraded for 2014. Ample power handling, ease of use, and excellent sound quality are all hallmarks of the Hot Spot line of monitors, and the MS5 will not disappoint. Get rid of those clunky old floor wedges, and get into the 21st century!
List Price$109.99
You Save27%
$79.99
Part # 245-2422
  • Small but mighty personal monitor
  • Super convenient volume control
  • 16 ohm impedance is easy on any amp
  • Parallel 1/4" inputs for simple daisy-chaining
So small, so convenient, but so powerful and clear, you'll wonder how you ever got along without something like the MS5 Micro Spot. Galaxy Audio is famous for the Hot Spot line of personal monitors, and the Micro Spot is among the latest additions to this winning line. The Micro Spot was designed for vocalists and instrumentalists who need to monitor their own performance, without all the lugging around and hassle associated with typical floor wedges. With a look and feel similar to the outrageously popular HS7 Hot Spot, the Micro Spot has parallel 1/4" inputs to allow seamless integration into an exisiting monitor setup. It boasts a single 5" full range driver which can handle up to 100 watts of power, and puts the volume control right on the front panel, allowing you to adjust the level of your monitor as often as you wish, without affecting anyone else, and without running to the monitor board. You can mount the Micro Spot directly to a mic stand, or use the included bracket as a wall, ceiling, or surface mount, allowing you to put the powerful sound virtually anywhere you need it, quickly, conveniently, and with the confidence that comes from Galaxy Audio's quality and reliability.
Specifications: • Power handling: 100 watts • Frequency range: 150 - 15,000 Hz • Maximum SPL: 113 dB • Impedance: 16 ohms • Inputs: 1/4" x 2 (parallel) • Dimensions: 6.25" x 6" x 7.5" (159 x 152 x 191 mm) • Weight: 4.01 lbs. (1.82 kg).
  • ConfigurationStage Monitor
  • Woofer Size5"
  • BrandGalaxy Audio
  • ModelMS5
  • Part Number245-2422
  • UPC691281104664
  • Weight6.0500 lbs.
View similar products to the Galaxy Audio MS5 Micro Spot Full Range Monitor with Volume Control
