Galaxy Audio JIB/CT 6-in-1 Pro Audio Cable Tester
Brand:|Model: JIB/CT|Part # 245-2402
The Galaxy Audio JIB/CT is a simple but effective means of testing virtually all your audio cables. Test XLR, 1/4", RCA, 3.5 mm, twist-lock (speakON), and MIDI cables quickly and reliably, and never be the victim of a bad cable again.
ORDER TODAY
Ships in 7-10 Business Days
List Price$79.99
You Save25%
$59.99
Part # 245-2402
  • 6-in-1 cable tester for musicians, contractors, and sound pros
  • Checks all the most popular connector types
  • Easy to read PASS/FAIL indicator lights
  • Saves you time, money, and headaches
We all know how frustrating it can be when you know you have a bad cable somewhere in the system, but you're just not sure which cable it is. Out of a hundred. Your audience and the folks who hired you to perform really don't care which cable it is. They expect to see and hear your show, and they expect it now. Avoid this nightmare by testing your cables before it's too late, with the Galaxy Audio JIB/CT 6-in-1 cable tester.
With the JIB/CT, you can test XLR, 1/4" (TS or TRS), RCA, 3.5 mm (1/8" headphone), twist-lock (speakON), and MIDI (DIN) cables just about as quickly as you can plug them in, with easy-to-read PASS/FAIL feedback in the form or a red or green LED. Unlike many cable checkers, the JIB/CT uses a computer-controlled circuit to test your cable 200 times per second, which can identify intermittent shorts, or cables which may work some of the time when "jiggled around just right," but not reliably. Simply plug in both ends of the cable (or adapter cable, or splitter "Y" cable), set the rotary selector to the correct number of conductors, and you're done. Easy as that.
As a performer or sound pro, you have enough to worry about when getting ready for a show. Get a JIB/CT cable tester, invest a few minutes to test your cables periodically, and make sure you have one less thing to worry about.
  • BrandGalaxy Audio
  • ModelJIB/CT
  • Part Number245-2402
  • UPC691281600043
  • Product CategoryCable Checkers
  • Weight0.7500 lbs.
View similar products to the Galaxy Audio JIB/CT 6-in-1 Pro Audio Cable Tester
in the Cable Checkers product category.
