245-255_ALT_0
245-255_ALT_1
245-255_ALT_2
245-255_ALT_3
Galaxy Audio HS7 Hot Spot 7 Vocal Monitor w/ Volume Control
Brand:| Model: HS7
There is an all new design of the Hot Spot for 2010. The Hot Spot has evolved over the past 3 decades and Galaxy Audio's new HS7 utilizes the same neodymium driver as its most recent predecessor with one significant improvement—there is more bass output.
  • High impact ABS plastic cabinet
  • Mounts on any mic stand with included MSA-1 spun aluminum stand adapter
  • 18 dB stepped attenuator volume control
  • Integrated handle into the top of the enclosure
  • 16 ohm cabinet with two NEOLITE 5" drivers
  • 200 Watts continuous power rating
  • Frequency response: 150 Hz-18 kHz
245-255
Weight: 6.4 lbs.
IN STOCK
Order Soon - Only 2 Left In Stock
List Price$199.99
You Save30%
$139.99
Part # 245-255
There is an all new design of the Hot Spot for 2010. The Hot Spot has evolved over the past 3 decades and Galaxy Audio's new HS7 utilizes the same neodymium driver as its most recent predecessor with one significant improvement—there is more bass output. The new shell is slightly larger with many cool new "built-ins" such as built-in mic stand mount, mic boom attachment, integrated handle, and more. Being that there is more room inside the cabinet, this creates better bass response.
Specifications: • Power handling: 200 watts RMS • Impedance: 16 ohms • Frequency response: 150-18,000 Hz • Sensitivity: 96 dB 1W/1m • Net weight: 5.25 lbs. • Dimensions: 7.75" x 11.75" x 6.75".
  • ConfigurationStage Monitor
  • Woofer Size5"
  • BrandGalaxy Audio
  • ModelHS7
  • Part Number245-255
  • UPC691281100239
    (2 Reviews)
  • Weight6.4 lbs.
View similar products to the Galaxy Audio HS7 Hot Spot 7 Vocal Monitor w/ Volume Control
Galaxy Audio HS7 Hot Spot 7 Vocal Monitor w/ Volume Control is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Lots of volume in a small packageI have used older Hot Spots and this is quite an improvement! The case incorporates a built in handle and speaker grills. The connectors are great with parallel combo 1/4" and speakon jacks. They have rolled off the bass for more power - perfect for vocals. Only one minor complaint. Galaxy supplies a mic stand adaptor. If you lose it, $10 for a new one!
Date published: 2014-10-07
Rated 5 out of 5 by from Great little monitor!Our band has five of these, we've been using them for about a year. Typical floor monitors are heavy, bulky, take up stage space let alone vehicle space when you're hauling to the gig. These monitors have eliminated those issues. They mount easily on a mic stand w/ the included adapter. Having them closer to your ears and the frequency band they project allow you to easily hear them without blasting the extra stage volume that is required with floor monitors.
Date published: 2011-12-10
Customer projects that include: Galaxy Audio HS7 Hot Spot 7 Vocal Monitor w/ Volume Control
