Fourjay SDT4K-RE8 8" Ceiling Speaker Assembly with Volume Control
Brand:|Model: SDT4K-RE8|Part # 300-354
Factory assembled and pre-tested to pass the highest quality standards. Fitted with a 25/70 volt transformer and a recessed 50 ohm volume control. 12-1/2" overall diameter.
$59.69
Buy 4-19 $56.24
Buy 20+$48.13
Part # 300-354
Factory assembled and pre-tested to pass the highest quality standards. The SDT4K-RE8 utilizes a corrosion resistant, 22 gauge galvanized steel grill with ceiling powder coated non-glare finish, which meets UL 1480 baffle requirements. It has an impedance of 8 ohms and is rated at 15 watts. The SDT4K-RE8 is fitted with a 25/70 volt transformer and a recessed 50 ohm volume control. 12-1/2" overall diameter.
Speaker Model #Q88D10
Transformer Model T427
Size & Style8" RoundPower Rating4 Watts
Magnet Weight & Type10 oz. CeramicPrimary Voltage25 & 70
Speaker TypeDual ConeInsertion Loss @ 1 KHz0.9 dB
Power Rating25 WattsFrequency Response80-20,000 Hz
Sensitivity100 dBPrimary Taps4, 2, 1, 1/2 Watts
Response30-19,000 HzPrimary Leads6" Color Coded
Impedance8 OhmsSecondary Impedance8 Ohms
Coil Diameter1"Secondary Leads6" Color Coded
Depth2-7/8"Mounting Centers2"
Weight2.1 Lbs.Weight0.42 Lbs.
2001 Parts Express. All Rights Reserved
  • Input Rating8 ohm,70V,25V
  • Mounting StyleIn-ceiling
  • Special FeaturesUL1480,Volume Control
  • Woofer Diameter8"
  • BrandFourjay Industries
  • ModelSDT4K-RE8
  • Part Number300-354
  • UPC844632007538
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Weight4.6596 lbs.
View similar products to the Fourjay SDT4K-RE8 8" Ceiling Speaker Assembly with Volume Control
in the In-Ceiling / On-Ceiling Speakers product category.
What kind of wire do I need to connect these
Asked by: techbex
I use this wire as my default wire for all installations.http://www.parts-express.com/pe/showdetl.cfm?Partnumber=101-227There's the link.Very good wire, well protected, good price point. Especially versus the nerdy monster wire crowd. Check this link.http://www.google.com/#hl=en&sclient=psy-ab&q=monster+wire+worth+it&oq=monster+wire+worth+it&aq=f&aqi=&aql=&gs_l=hp.12...0l0l4l1526l0l0l0l0l0l0l0l0ll0l0.frgbld.&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=dcfb21c058468efb&biw=1152&bih=715It's a google query for "monster wire worth it".I do home theater installations on a regular basis.I use this wire because of the aforementioned reasons.The speakers referred to in this question are rated at 4 watts, so you could probably get away with 18 gauge wire also. Here's a link.http://www.parts-express.com/pe/showdetl.cfm?PartNumber=100-712And to wrap this up, I prefer a closed back speaker forwhole house or 5.1. Dayton makes a good closed back ceiling speaker for a great price. Used it for 5.1 and whole house with very good results. Here's a link.Really good speaker for the price.http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-417%20%20%20%20%20%20%20%20&FTR=300-417&CFID=28347408&CFTOKEN=57952805Take care,Jimmy
Answered by: jbiringer3
Date published: 2012-03-28
  • 2016-02-14T07:37CST
  • loc_en_US, sid_300-354, PRD, sort_recentQuestionsFirst
