Fourjay 440-8 Thundering Mini Horn Speaker
Brand:|Model: 41423|Part # 300-066
Designed for good speech intelligibility, the 440-8 Thundering Mini is ideal for two-way communications on trucks, heavy equipment, boats, helicopters, etc. and provides excellent sensitivity as a microphone in talk-back systems.
$76.86
Buy 6+$69.94
Part # 300-066
Designed for good speech intelligibility, the 440-8 Thundering Mini is ideal for two-way communications on trucks, heavy equipment, boats, helicopters, etc. and provides excellent sensitivity as a microphone in talk-back systems. The 440-8 is a small re-entrant horn package with a powerful, efficient and durable compression driver which converts security system square wave torture into a high output distress signal. A heat sink coupled to the driver dissipates heat to maintain efficiency and endurance. Weather and corrosion resistant construction uses stainless steel fasteners and the plating on the driver meets a 96-hour salt spray test, while the horn itself is constructed of impact and UV resistant ABS. The adjustable mounting base will attach to a 3-inch electrical box. Flange holes allow for recessed or concealed mounting. The 440-8 comes with a 30' black jacketed cable for fast "hard wiring" and good weatherability. Tan horn with brown diffuser/inner horn. Mfg. #440-8. Made in the U.S.A.
Specifications: • Rated input: 8 ohms • Power handling: 40 watts continuous duty • Frequency range: 700-6,500 Hz • Sensitivity: 107 dB • Net weight: 2-1/2 lbs.
  • Speaker TypePA Horn Speaker
  • BrandFourjay Industries
  • Model41423
  • Part Number300-066
  • UPC844632007330
  • Product CategoryPA Horn Speakers for Music & Paging
  • Weight3.4848 lbs.
View similar products to the Fourjay 440-8 Thundering Mini Horn Speaker
in the PA Horn Speakers for Music & Paging product category.
The wires are black and white, I'm presuming white is positive and black is negative?
Asked by: Jack45
Yes that is correct.
Date published: 2013-12-11
What are the Dimensions?
Diameter of the Bell?Depth?
Asked by: emersonb
Please refer to the manufacturer's specifications, to the right, under "Manuals/Resources." There is a technical drawing in that document.
Answered by: RussR
Date published: 2012-05-16
  • 2016-02-11T07:06CST
  • loc_en_US, sid_300-066, PRD, sort_recentQuestionsFirst
