Fountek NeoCD3.5H Horn Loaded Ribbon Tweeter
Brand:|Model: NeoCD3.5H|Part # 296-703
Fountek’s NeoCD3.5H is a unique horn-loaded true ribbon tweeter that combines high sensitivity with the exceptional speed and detail of ribbon technology.
List Price$94.99
You Save27%
$68.90
Buy 4+$65.50
Part # 296-703
  • Horn-loaded, true ribbon design
  • 2.36" H x 0.35" W ribbon element
  • 95.5 dB sensitivity combined with 1,100 to 30,000 Hz frequency response
  • Extremely fast transient response with wide horizontal dispersion
Fountek, an innovator in ribbon transducer technology, is the first to mate true ribbon technology with horn-loading for high efficiency and low distortion with their NeoCD3.5H . A reinforced sandwiched-aluminum ribbon diaphragm and strong neodymium motor structure are extremely responsive, and deliver musical detail with speed and accuracy, from 1,100 to 30,000 Hz, while the wide horizontal off-axis dispersion makes for a larger listening sweet spot.
A taller element is used in the NeoCD3.5H, which tames vertical off-axis dispersion. This helps to minimize ceiling and floor bounce reflections for world-class, pin-point precise imaging, while the focused output also reduces the amount of sound pressure level drop over distance. Recommended minimum crossover frequency: 2,500 Hz @ 18 dB/octave.
  • Tweeter TypeRibbon
  • Impedance7 ohms
  • Power Handling (RMS)12 Watts
  • Frequency Response1,100 to 30,000 Hz
  • Sensitivity95.5 dB 1W/1m
  • DC Resistance (Re)0.02 ohms
  • Overall Outside Diameter4.33" x 3.86"
  • Cutout Diameter3.39" x 2.70 "
  • Depth3.94"
  • BrandFountek
  • ModelNeoCD3.5H
  • Part Number296-703
  • UPC848864004105
  • Product CategoryTweeters
  • Weight1.55 lbs.
View similar products to the Fountek NeoCD3.5H Horn Loaded Ribbon Tweeter
in the Tweeters product category.
This driver will work with the crossover 4th order on the point 2000Hz?
Asked by: ks61v
Based on the response curve I see no reason this wouldn't work crossed that low fourth order.
Date published: 2016-01-22
I would like to build a separate boxes for the Fountek NeoCD3.5H ribbon tweeter but would need a crossover.  Would the Eminence PXB:3K5 keep the ribbons safe?  If not a good match, do you have something I could consider? Thanks! -mike
Asked by: msutliff
Yes that crossover will work well with this tweeter.
Date published: 2015-08-31
Could this pair well with a Dayton PA310? What is roughly the max SPL?
Asked by: monoiz15
Yes this should work well with that woofer. Based on the power handling of the horn the maximum output will be 104-105 dB, but this power is considered with a full range signal so realistic output should be much higher.
Date published: 2015-04-26
  • 2016-02-12T07:02CST
  • loc_en_US, sid_296-703, PRD, sort_recentQuestionsFirst
