Fountek FW168 6-1/2" Aluminum Midwoofer Speaker
Brand:|Model: FW168|Part # 296-729
Fountek’s FW168 is a robust 6-1/2" midbass driver that features an attractive aluminum cone and phase plug, a high-strength cast-aluminum frame, and an optimized motor structure, for low distortion and excellent detail.
List Price$59.99
You Save23%
$45.95
Buy 4+$43.76
Part # 296-729
  • Elegant satin anodized-aluminum cone with phase plug
  • Low-distortion design with extremely fast transient response
  • Long-throw voice coil with 4.6 mm of Xmax for impressive low end performance
  • Non-resonant cast aluminum frame
Fountek midbass drivers offer exceptional value with premium features like aluminum cones and phase plugs, robust cast frames, and optimized low-distortion motors.  They are the perfect choice for use in high-end loudspeaker systems, paired with premium-quality tweeters like Fountek’s own ribbon units.
The FW168 6-1/2” model is similar to the smaller 5-1/4” FW146 model in design and cosmetics, but provides deeper bass extension for use in larger monitor and floor-standing speakers. It features the same cast frame and satin-anodized aluminum cone as the other Fountek midwoofer drivers, for an aesthetically seamless match.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response40 to 4,000 Hz
  • Sensitivity87.3 dB 1W/1m
  • Voice Coil Diameter1.42"
  • Resonant Frequency (Fs)45 Hz
  • DC Resistance (Re)7.2 ohms
  • Mechanical Q (Qms)3.25
  • Electromagnetic Q (Qes)0.45
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.58 ft.³
  • Mechanical Compliance of Suspension (Cms)0.82 mm/N
  • BL Product (BL)8.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)14.7g
  • Moving Mass Of Diaphragm (Mmd)13.96
  • Maximum Linear Excursion (Xmax)4.6 mm
  • Surface Area of Cone (Sd)119 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter7.01"
  • Baffle Cutout Diameter5.75"
  • Depth2.95"
  • Bolt Circle Diameter6.61"
  • # Mounting Holes4
  • Sealed Volume0.18 ft.³
  • Sealed F391 Hz
  • Vented Volume0.44 ft.³
  • Vented F349 Hz
  • BrandFountek
  • ModelFW168
  • Part Number296-729
  • UPC848864004235
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight4.1 lbs.
View similar products to the Fountek FW168 6-1/2" Aluminum Midwoofer Speaker
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
