Fountek FW146 5-1/4" Aluminum Midwoofer Speaker
Brand:|Model: FW146|Part # 296-727
Fountek’s FW146 is a robust 5-1/4" midbass driver that features an attractive aluminum cone (and phase plug), a high-strength cast-aluminum frame, and an optimized motor structure for low distortion and excellent detail.
List Price$47.99
You Save23%
$36.85
Buy 4+$35.10
Part # 296-727
  • Elegant satin anodized-aluminum cone with phase plug
  • Long-throw voice coil for dynamic bass
  • Linear response up to 5,000 Hz for easy integration with tweeters
Fountek midbass drivers offer exceptional value with premium features like aluminum cones and phase plugs, robust cast frames, and optimized low-distortion motors.  They’re the perfect choice for use in high-end loudspeaker systems, paired with premium-quality tweeters like Fountek’s own ribbon units.
The FW146 5-1/4” midwoofer is the perfect choice for compact mini-monitor speaker projects, or as a midrange in a three-way configuration together with a dedicated woofer. The aluminum cone and phase plug feature a discreet, stylish satin anodized finish, and the cast frame adds structural rigidity to the driver.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)35 Watts
  • Power Handling (max)70 Watts
  • Impedance8 ohms
  • Frequency Response45 to 4,000 Hz
  • Sensitivity86.1 dB 1W/1m
  • Voice Coil Diameter1.02"
  • Resonant Frequency (Fs)50 Hz
  • DC Resistance (Re)6 ohms
  • Mechanical Q (Qms)3.51
  • Electromagnetic Q (Qes)0.46
  • Total Q (Qts)0.4
  • Compliance Equivalent Volume (Vas)0.35 ft.³
  • Mechanical Compliance of Suspension (Cms)1.14 mm/N
  • BL Product (BL)6.07 Tm
  • Diaphragm Mass Inc. Airload (Mms)8.94g
  • Moving Mass Of Diaphragm (Mmd)8.54
  • Maximum Linear Excursion (Xmax)3.6 mm
  • Surface Area of Cone (Sd)77.61 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.73"
  • Baffle Cutout Diameter4.53"
  • Depth2.7"
  • Bolt Circle Diameter5.35"
  • # Mounting Holes4
  • Sealed Volume0.12 ft.³
  • Sealed F398 Hz
  • Vented Volume0.29 ft.³
  • Vented F352 Hz
  • BrandFountek
  • ModelFW146
  • Part Number296-727
  • UPC848864004228
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight3 lbs.
View similar products to the Fountek FW146 5-1/4" Aluminum Midwoofer Speaker
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
