Fountek FR89EX 3" Neodymium Full Range Speaker Driver
Brand:|Model: FR89EX|Part # 296-721
Fountek’s FR89EX full range driver features an attractive black anodized aluminum cone, robust cast-aluminum frame, and an optimized long-excursion neodymium motor, for low distortion and excellent detail.
List Price$64.99
You Save24%
Buy 4+$47.05
Part # 296-721
  • Smooth, extended frequency response from 70 to 20,000 Hz
  • High-excursion design with 5 mm of Xmax
  • Neodymium motor with underhung voicecoil design
  • Black anodized-aluminum diaphragm
  • Cast aluminum frame
Fountek has applied much of what it has learned from designing industry-leading ribbon transducers in creating its line of full-range drivers. These high-performing cone drivers feature thin-foil aluminum diaphragms that shed resonance rapidly, for exceptional detail and smooth frequency response.
The 3" FR89EX model features a high-strength neodymium motor structure with underhung geometry, for low distortion, extended excursion, and excellent transient response. It’s a great choice for compact projects that demand the very best performance from a small full-range driver.
  • Nominal Diameter3"
  • Power Handling (RMS)25 Watts
  • Power Handling (max)50 Watts
  • Impedance8 ohms
  • Frequency Response70 to 20,000 Hz
  • Sensitivity83.6 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)97 Hz
  • DC Resistance (Re)5.7 ohms
  • Mechanical Q (Qms)1.64
  • Electromagnetic Q (Qes)0.65
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.04 ft.³
  • Mechanical Compliance of Suspension (Cms)0.99 mm/N
  • BL Product (BL)3.78 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.61g
  • Moving Mass Of Diaphragm (Mmd)2.69
  • Maximum Linear Excursion (Xmax)5 mm
  • Surface Area of Cone (Sd)27.34 cm²
  • Cone MaterialAluminum
  • Surround MaterialPolyurethane
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.48"
  • Baffle Cutout Diameter2.87"
  • Depth1.68"
  • Bolt Circle Diameter3.19"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3166 Hz
  • Vented Volume0.05 ft.³
  • Vented F382 Hz
  • BrandFountek
  • ModelFR89EX
  • Part Number296-721
  • UPC848864004198
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (2 Reviews)
  • Weight1.25 lbs.
View similar products to the Fountek FR89EX 3" Neodymium Full Range Speaker Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
