Fountek FR88EX 3" Neodymium Full Range Speaker Driver
Brand:|Model: FR88EX|Part # 296-719
Fountek’s FR88EX full range driver features an attractive thin-foil aluminum cone, robust cast-aluminum frame, and an optimized high-strength neodymium motor, for low distortion and excellent detail.
List Price$51.99
You Save27%
$37.80
Buy 4+$35.50
Part # 296-719
  • Attractive thin-foil aluminum diaphragm
  • Strong neodymium motor
  • High-excursion design
  • Smooth, extended frequency response
  • Cast aluminum frame
Fountek has applied much of what it has learned from designing industry-leading ribbon transducers in creating its line of full-range drivers. These high-performing cone drivers feature thin-foil aluminum diaphragms that shed resonance rapidly, for exceptional detail and smooth frequency response.
The FR88EX model features a high-strength neodymium motor structure for low distortion, extended excursion, and excellent transient response. Its advanced design makes it a true high-end contender in small full-range drivers.
  • Nominal Diameter3"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response95 to 20,000 Hz
  • Sensitivity84.3 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)95 Hz
  • DC Resistance (Re)6 ohms
  • Mechanical Q (Qms)1.96
  • Electromagnetic Q (Qes)0.62
  • Total Q (Qts)0.47
  • Compliance Equivalent Volume (Vas)0.04 ft.³
  • Mechanical Compliance of Suspension (Cms)1.2 mm/N
  • BL Product (BL)3.31 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.36g
  • Moving Mass Of Diaphragm (Mmd)2.27
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)27.34 cm²
  • Cone MaterialAluminum
  • Surround MaterialPolyurethane
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter3.48"
  • Baffle Cutout Diameter2.87"
  • Depth1.5"
  • Bolt Circle Diameter3.19"
  • # Mounting Holes4
  • Sealed Volume0.2 ft.³
  • Sealed F3161 Hz
  • Vented Volume0.05 ft.³
  • Vented F379 Hz
  • BrandFountek
  • ModelFR88EX
  • Part Number296-719
  • UPC848864004181
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (5 Reviews)
  • Weight0.9 lbs.
View similar products to the Fountek FR88EX 3" Neodymium Full Range Speaker Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
