Fountek FR58EX 2" Neodymium Full Range Speaker Driver
Brand:|Model: FR58EX|Part # 296-725
Fountek’s FR58EX is a premium 2" small full-range driver that features an attractive thin-foil aluminum cone, steel frame, and an optimized high-strength neodymium motor, for low distortion and excellent detail.
List Price$23.99
Regular Price$18.65
You Save20%
Sale Price
Part # 296-725
  • Ultra-linear frequency response from 150 to 20,000 Hz
  • Gorgeous aluminum cone
  • Neodymium motor with 2.9 mm of Xmax
  • Extremely fast transient response for clear, accurate high end
Fountek has applied much of what it has learned from designing industry-leading ribbon transducers in creating its line of full-range drivers. These high-performing cone drivers feature thin-foil aluminum diaphragms that shed resonance rapidly, for exceptional detail and smooth frequency response.
The 2" FR58EX model is the smallest, and features a high-strength neodymium motor structure for low distortion, extended excursion, and excellent transient response. It’s a great choice for desktop multimedia speakers, micro-satellite speakers, or line arrays.
  • Nominal Diameter2"
  • Power Handling (RMS)15 Watts
  • Power Handling (max)30 Watts
  • Impedance8 ohms
  • Frequency Response130 to 20,000 Hz
  • Sensitivity82.3 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)134 Hz
  • DC Resistance (Re)6.4 ohms
  • Mechanical Q (Qms)2.6
  • Electromagnetic Q (Qes)0.69
  • Total Q (Qts)0.55
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • BL Product (BL)3.39 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.91g
  • Moving Mass Of Diaphragm (Mmd)1.87
  • Maximum Linear Excursion (Xmax)2.9 mm
  • Surface Area of Cone (Sd)17.35 cm²
  • Cone MaterialAluminum
  • Surround MaterialPolyurethane
  • Voice Coil FormerAluminum
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.44" x 2.44"
  • Baffle Cutout Diameter2.02"
  • Depth1.3"
  • Bolt Circle Diameter2.6"
  • # Mounting Holes4
  • Sealed Volume0.01 ft.³
  • Sealed F3196 Hz
  • Vented Volume0.02 ft.³
  • Vented F395 Hz
  • BrandFountek
  • ModelFR58EX
  • Part Number296-725
  • UPC848864004211
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (11 Reviews)
  • Weight0.4 lbs.
