Fountek FE85 3" Full Range Speaker Driver
Brand:|Model: FE85|Part # 296-717
Fountek’s FE85 features an attractive thin-foil aluminum cone, cosmetic stamped frame, and a high-performance ferrite motor structure.
List Price$17.99
You Save29%
Buy 4+$11.20
Part # 296-717
  • Attractive thin-foil aluminum diaphragm
  • Cosmetic stamped steel frame
  • Economical ferrite motor structure
  • Ultra-fast transient response
Fountek has applied much of what it has learned from designing industry-leading ribbon transducers in creating its line of full-range drivers. These high-performance cone drivers feature thin-foil aluminum diaphragms that shed resonance rapidly for exceptional detail and smooth frequency response.
The FE85 model features a generously-proportioned ferrite motor structure and a cosmetic steel frame to complement its high-tech diaphragm, creating an affordable, high-value driver choice for compact applications such as desktop speakers, mini-satellites, or line arrays.
  • Nominal Diameter3"
  • Power Handling (RMS)12 Watts
  • Power Handling (max)25 Watts
  • Impedance8 ohms
  • Frequency Response100 to 25,000 Hz
  • Sensitivity85.7 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)125 Hz
  • DC Resistance (Re)6 ohms
  • Mechanical Q (Qms)2.13
  • Electromagnetic Q (Qes)0.67
  • Total Q (Qts)0.52
  • Compliance Equivalent Volume (Vas)0.03 ft.³
  • Mechanical Compliance of Suspension (Cms)0.82 mm/N
  • BL Product (BL)3.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)2.07g
  • Moving Mass Of Diaphragm (Mmd)1.99
  • Maximum Linear Excursion (Xmax)1.5 mm
  • Surface Area of Cone (Sd)27 cm²
  • Cone MaterialAluminum
  • Surround MaterialPolyurethane
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter3.55"
  • Baffle Cutout Diameter2.76"
  • Depth1.56"
  • Bolt Circle Diameter3.29"
  • # Mounting Holes4
  • Sealed Volume0.02 ft.³
  • Sealed F3196 Hz
  • Vented Volume0.05 ft.³
  • Vented F394 Hz
  • BrandFountek
  • ModelFE85
  • Part Number296-717
  • UPC848864004174
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (14 Reviews)
  • Weight1.1 lbs.
